albert Posted February 15, 2018 Author Posted February 15, 2018 OK I've decided to go with Biopure very helpfull and good back up on phone if needed. Im going with a bio pure 3 and plan to install under building regs binding rules. I am unsure as this rule is unclear on distance the plant should be located from the ditch if it is discharging directly into it. 10m is stated if you use a soakaway so would assume 10m for tank would be OK. Many thanks
Jeremy Harris Posted February 15, 2018 Posted February 15, 2018 Ours is around 6 or 7 metres from the stream it discharges to, and BC didn't have any problems with that at all. They were also pretty flexible about the location, because there wasn't much room to play with when it came to positioning the thing and still keeping reasonable falls.
ProDave Posted February 15, 2018 Posted February 15, 2018 The plant has to be 10 metres from a watercourse (In Scotland) Though a neighbour has installed one a lot closer, waiting to see if BC sign it off or not.
