Hi
When our timber frame is erected we will have an ugly galvanised post holding up the corner of the porch. We are planning to match the house brick plinth height on the post, but how can we clad the post to make it look a bit more elegant.
For context the house will be white rendered with composite cladding.
Thanks
Images help, if you could add that would be great.
Also does this steel post act as a thermal bridge?
Yes, section dwgs wd be great. Could the post perhaps sit on compacfoam at btm and have a further chunk of said compacfoam at the top?
If you know what 'look' you want, why not simply have the post made with the necessary 'tangs' to which to mount your cladding/expanded metal/what you will?
