mjc55 Posted July 29, 2025 Posted July 29, 2025 Anyone have a go to supplier for 16mm 5 core armoured cable? Going to need about 50m I think. Thanks
JohnMo Posted July 29, 2025 Posted July 29, 2025 Just ring around all your local electrical factors, prices will vary depending on the person you talk to
nod Posted July 29, 2025 Posted July 29, 2025 I found Screwfix beat most of the suppers British made Don’t buy the online Turkish shite was the advice I received
mjc55 Posted July 29, 2025 Author Posted July 29, 2025 41 minutes ago, nod said: I found Screwfix beat most of the suppers British made Don’t buy the online Turkish shite was the advice I received Don't seem to do 16mm 5 core armoured.
Nickfromwales Posted July 29, 2025 Posted July 29, 2025 1 hour ago, mjc55 said: Don't seem to do 16mm 5 core armoured. Why 5 core? You usually have to run a separate 16mm2 or 10mm2 PVC earth along side this size of cable, or earth locally if too far/wrong supply type to export the earth connection. What’s it for/doing?
mjc55 Posted July 30, 2025 Author Posted July 30, 2025 Advice from electrician. It will run from meter to the "pod" that we will live in whilst building house. Will be part of 3-phase setup. Pod will have all the usual sockets and lights, cooker, electric shower, water heating of some form and electric UFH.
Nickfromwales Posted July 30, 2025 Posted July 30, 2025 3 hours ago, mjc55 said: Advice from electrician Should mean you don't need to be asking here? Why has he asked you for a cable that isn't available? Is the pod to be metal clad (standing seam)? 3 hours ago, mjc55 said: It will run from meter to the "pod" that we will live in whilst building house. Will be part of 3-phase setup. Pod will have all the usual sockets and lights, cooker, electric shower, water heating of some form and electric UFH. Do you have a pic of the meter location, and do you know the type of supply (PME/other)? 1
mjc55 Posted July 30, 2025 Author Posted July 30, 2025 managed to get hold of some 5 core 16mm armoured from Superlec!
Onoff Posted July 30, 2025 Posted July 30, 2025 (edited) It's available from various places but why? https://quickbit.co.uk/16mm-5-core-swa-cable-per-metre/ Better to run 4-core 16mm² and a separate CPC (earth) if exporting but again why, just rod the outbuilding. Whatever, run it in a duct. Edited July 30, 2025 by Onoff Rod not rid!
Nickfromwales Posted July 31, 2025 Posted July 31, 2025 1 hour ago, Onoff said: It's available from various places but why? https://quickbit.co.uk/16mm-5-core-swa-cable-per-metre/ Better to run 4-core 16mm² and a separate CPC (earth) if exporting but again why, just rod the outbuilding. Whatever, run it in a duct. Yup. Electrician is not shining here tbh. 1
Nickfromwales Posted July 31, 2025 Posted July 31, 2025 If this is over 45-50m then you really shouldn’t be exporting the earth? What’s your sparky got to say about this?
mjc55 Posted July 31, 2025 Author Posted July 31, 2025 1 hour ago, Nickfromwales said: If this is over 45-50m then you really shouldn’t be exporting the earth? What’s your sparky got to say about this? I will ask him. 1
