Lin Posted December 31, 2017 Posted December 31, 2017 Not sure if this is the best forum for this... We were thinking of having all services go through into the utility room of the house, meters on outside. Is there any good reason not to have these connections go through the wall in close proximity ?? ... could be reasons of safety/regs, aesthetics, convenience or anything else Can they share a trench?
Onoff Posted December 31, 2017 Posted December 31, 2017 There are set distances between services and trench depths. Broadly speaking all areas follow pretty much the same guidelines but some service providers insist on certain colour ducts underground such as red instead of black for electricity. Whereabouts are you roughly and we'll go from there.
nod Posted December 31, 2017 Posted December 31, 2017 1 hour ago, Lin said: Not sure if this is the best forum for this... We were thinking of having all services go through into the utility room of the house, meters on outside. Is there any good reason not to have these connections go through the wall in close proximity ?? ... could be reasons of safety/regs, aesthetics, convenience or anything else Can they share a trench? My gas and electric are about a metre apart and come through the study wall The water is 5 mtrs further along All share the same trench Water in first Gas and electric on top But as Onoff has already pointed out Mpst suppliers are very strict about trench depths and the ducting that you use 1
Onoff Posted December 31, 2017 Posted December 31, 2017 (edited) Western Power then: https://www.google.co.uk/url?sa=t&source=web&rct=j&url=https://www.westernpower.co.uk/docs/connections/Moving-Supply-Guide.aspx&ved=0ahUKEwiL_syNs7TYAhUjBMAKHU3bC1YQFghcMAo&usg=AOvVaw0cG4nCe5Tj0dbuIsDJJTrh & https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.hse.gov.uk/pUbns/priced/hsg47.pdf&ved=0ahUKEwjq-86YtLTYAhVbFMAKHddaBqYQFggdMAA&usg=AOvVaw0dPNWnqyjY4KU_6_cK13l9 & This Openreach doc contains the useful Joint Utilities diagram. Tbh I'd worry more about the depths than having a 2m wide trench and pinch a bit here and there! https://www.google.co.uk/url?sa=t&source=web&rct=j&url=https://www.ournetwork.openreach.co.uk/resources/site1/General/Downloads/quick-guides/Quick_Guide_Duct_Laying.pdf&ved=0ahUKEwjVjqrrtrTYAhUFOsAKHQT_BTUQFghzMA8&usg=AOvVaw1_8NqgnwuSWGYLa7zs_aOc Tbh if you ignore the distance to the house and footpath it's about a metre wide trench. Edited December 31, 2017 by Onoff 1 1
Nickfromwales Posted December 31, 2017 Posted December 31, 2017 Once inside you only need 150-200mm between gas and electric in Wales.
