ruggers Posted July 21 Posted July 21 In a masonry constructed house 100 face brick / 150 partial fill cavity/ 100 dense block and using catnic style lintels. Are trays required below the window sills? Above them a dpc roll can be used with turned up ends into the perps, would this be 450 or 600 roll? The plastic cavity trays for above were going to be really expensive if made to suit, unless people use off the shelf ones? Builder only uses catnic and says above opening trays arent required which ive said im using birtley and 100% want them as its been warranty criteria for decades.
nod Posted July 21 Posted July 21 Turned up dpc is fine Above window and door openings I don’t see how the warranty company can dictate how you build your house Tell them to f**k off 1
ruggers Posted July 21 Author Posted July 21 The warranty company hasn't said anything, I've just went with a local person for it, cheap as they come because its all a paperwork exercise really I'm self building and project managing separate trades. I just wanted to meet the essentials to have a leak free house since using face bricks, but not have to hassle the builder too much who's set in his ways being old. I cant see the benefit of trays under sills if I have proper ones over openings but its worth me asking. Some stone sill on the front, rest upvc. All set back 25mm into cavity.
nod Posted July 21 Posted July 21 1 hour ago, ruggers said: The warranty company hasn't said anything, I've just went with a local person for it, cheap as they come because its all a paperwork exercise really I'm self building and project managing separate trades. I just wanted to meet the essentials to have a leak free house since using face bricks, but not have to hassle the builder too much who's set in his ways being old. I cant see the benefit of trays under sills if I have proper ones over openings but its worth me asking. Some stone sill on the front, rest upvc. All set back 25mm into cavity. My mistake Warranty criteria Warranties rarely pay out The type of trays you use won’t make any difference to there cover A sheet of dpc over each opening is more than enough fore 99% of new homes 1
ruggers Posted July 22 Author Posted July 22 What size DPC would you use, 450 or 600? I tired 450 yesterday because i have some, and if fully bedded on the outer leaf, then angled up 225 and horizontally lapped in over the 100mm PIR, it beds in the inner skin by 50-60mm 100/150/100
