Pocster Posted July 12 Posted July 12 A few weeks ago I noticed my IT cupboard getting rather warm . So logically thought I’d be installing a fan in there and maybe a Shelly and zigbee temp sensor . Not a fan of Shelly based on my experience. Anyway link it all up to HA , easy !! Then I can across this - which I got on eBay for £17 . Chatgpt suggested this device which I’ve not heard of before ; inkbird ( funny name for a temp control unit ) It’s awesome ! . Dual plug outlets so one for a heating device and one for cooling . Temp sensor on a long flex . I think my expectation was “ typical Chinese shite “ - but it’s a cheaper solution not relying on HA . I use to trigger my fan 1
SteamyTea Posted July 12 Posted July 12 What load can each individual outlet take? Is the total constant load 10A?
joth Posted July 12 Posted July 12 (edited) You paid over the odds! £6.99 for a fan controller, and use any old PC fan. This is what I did for cooling my multi zone amp. Potentially* could power from the amp* 12v trigger output, even https://amzn.eu/d/9cjSv9L (I actually bought a nicer quiet noctura fan and nicked 12V from a nearby led PSU) I think I have a similar looking inkbird thing for the BBQ and smoker temperature controller. But yeah I'm a big fan* of stand alone cooling for devices. No need to wire it to the house brain. (Unless it's super noisy in which case a nighttime quiet mode maybe in order. ) * - no puns intended. Edited July 12 by joth 1
Pocster Posted July 12 Author Posted July 12 31 minutes ago, SteamyTea said: What load can each individual outlet take? Is the total constant load 10A? 10A per plug I.e 10A for heating and 10A for cooling
Pocster Posted July 12 Author Posted July 12 5 minutes ago, joth said: You paid over the odds! £6.99 for a fan controller Undoubtedly! . But it was cheaper than a Shelly and zigbee thermometer. The fact it works for £17 is where I’m happy 😃
SteamyTea Posted July 12 Posted July 12 (edited) 2 minutes ago, Pocster said: 10A per plug I.e 10A for heating and 10A for cooling I don't think so. But give it a go to prove me wrong. Or is it as case of one or the other but never bothered together. Edited July 12 by SteamyTea
Pocster Posted July 12 Author Posted July 12 1 minute ago, SteamyTea said: I don't think so. But give it a go to prove me wrong. What kind of bollock answer is that ! I simply took time to look at the instructions for you
SteamyTea Posted July 12 Posted July 12 27 minutes ago, Pocster said: What kind of bollock answer is that Says total output 1200W MAX. Bur it also says things for the USA market.
Pocster Posted July 12 Author Posted July 12 1 minute ago, SteamyTea said: Says total output 1200W MAX. Bur it also says things for the USA market. Buy one . Plug in your hot and cold dildos - see what happens
SteamyTea Posted July 12 Posted July 12 (edited) 33 minutes ago, Pocster said: dildos Only a small handful of what's. You sent it me remember. Just found the cold one in Widl. 99p And here is a sausage scourer for you. That is almost 3 quid I have wasted on you. Edited July 12 by SteamyTea
Pocster Posted July 12 Author Posted July 12 30 minutes ago, SteamyTea said: Only a small handful of what's. You sent it me remember. Just found the cold one in Widl. 99p And here is a sausage scourer for you. That is almost 3 quid I have wasted on you. You’re not scouring my sausage again!
SteamyTea Posted July 12 Posted July 12 25 minutes ago, Pocster said: You’re not scouring my sausage again It is a popular summer pastime down here. Why they have a waist height seawall. Happens every Tuesday evening at 8PM.
dpmiller Posted July 12 Posted July 12 I've used Inkbird DIN-rail controllers a few times and they're good kit. 1
