I had 3 x 180mm holes drilled, about the same length. IIRC it was about £250.
Whatever size you think you need drilled add 10mm, then foam the gaps after fitting the pipe. Don't ask why I know.
For a small number you might be best paying a day rate. 5 holes (from 63mm up to 200mm) half a day, two guys was £250.
