I am considering buying a Brink Flair 225 MVHR unit. I cannot find reviews and wonder if anyone can offer any opinion on this unit or the range?
Thanks
Thanks
I’ve been installing Brink units for all of my M&E projects since 2018 and can speak very highly of them.
Some have been passiv haus certified projects, and I have had great service / support from the guys at CVC Systems Ltd in Oxford.
If you buy through them (supply or supply and fit) you’ll get uk support vs buying from Ireland / other grey imports, and also these often are priced lower but don’t have controllers supplied in the box so end up same or more expensive but zero warranty support.
I bough what I now asume was a grey import and the built in web server setup page is in Dutch, I can't see an option to change it, but there is an option to upgrade the firmware via the USB socket. I don't know where to get the firmware though, it's not on the Brink site that I can see.  It also doesn't have an front control panel so all control is from the app or the 4 position switch. No a huge issue as when it's setup and running no real intervention is required. I didn't realise it was a grey import when I bought it. I'm happy with the performance, seems to just work.
