Would you recommend a Brink Flair?
I am considering buying a Brink Flair 225 MVHR unit. I cannot find reviews and wonder if anyone can offer any opinion on this unit or the range?
Thanks
Thanks
I’ve been installing Brink units for all of my M&E projects since 2018 and can speak very highly of them.
Some have been passiv haus certified projects, and I have had great service / support from the guys at CVC Systems Ltd in Oxford.
If you buy through them (supply or supply and fit) you’ll get uk support vs buying from Ireland / other grey imports, and also these often are priced lower but don’t have controllers supplied in the box so end up same or more expensive but zero warranty support.
Thanks very much Nickfromwales for the recommendation and tip.
I bough what I now asume was a grey import and the built in web server setup page is in Dutch, I can't see an option to change it, but there is an option to upgrade the firmware via the USB socket. I don't know where to get the firmware though, it's not on the Brink site that I can see.  It also doesn't have an front control panel so all control is from the app or the 4 position switch. No a huge issue as when it's setup and running no real intervention is required. I didn't realise it was a grey import when I bought it. I'm happy with the performance, seems to just work.
