Drellingore Posted September 2, 2025 Posted September 2, 2025 2 minutes ago, Gus Potter said: Where are you building? Kent, north of Folkestone. My username is the location... Although I should have pretended to be Dr. Ellingore! 2 minutes ago, Gus Potter said: Why are you replacing the existing concrete slab? It's very old, very not-flat, and we need to insulate under it otherwise we lose a lot of space. That's my understanding anyway; I tend to take the wife's word and the architect's word on such matters. 2 minutes ago, Gus Potter said: You should by this time have an SE fully on board giving you practical building advice and showing you where the costs lie in terms of buildability, working closely with your Architect, guiding them and encouraging design discussions.. unless you want to lose money. We do. They're saying radon is outside of their remit.
Gus Potter Posted September 2, 2025 Posted September 2, 2025 47 minutes ago, Drellingore said: It's very old, very not-flat, and we need to insulate under it otherwise we lose a lot of space. Ok, that sounds like a valid reason. You have a height restriction. 49 minutes ago, Drellingore said: We do. They're saying radon is outside of their remit. That's flag if they can't take this in their stride then oh dear! Radon is assocaited with granite rock. My gut feeling is that you are not paying your SE enought. Phone them up and have a frank conversation. Don't be afraid to step on your Architect's toes. Just say they ask you for an extra two or three grand to hold your hand. All they need to do is to save you a week of two men's skilled time on site + expenses. And how much are you going to spend! 56 minutes ago, Drellingore said: tend to take the wife's word and the architect's word on such matters. Then she should have told you to be the bad ass and knock heads together.
saveasteading Posted September 2, 2025 Posted September 2, 2025 Radon is simple. Maps show the risk level, by postcode even. If it needs protection it's a standard membrane and easy while constructing. If not, then not. But don't ignore it. Have you tried to put less insulation over your existing slab, and then balance it elsewhere? The rules can be adjusted too, esp as this would be a 'sustaimable' option ie not buying concrete. Are you looking at a few cm of problem or a lot?
Drellingore Posted September 3, 2025 Posted September 3, 2025 Ergh. BGS survey came back with >30% probability, so that'll be full mitigation.
saveasteading Posted September 3, 2025 Posted September 3, 2025 £1.50/ m2 and no normal dpm needed, or am I missing something?
Drellingore Posted September 3, 2025 Posted September 3, 2025 (edited) 26 minutes ago, saveasteading said: am I missing something Full mitigation means sumps and the like, as far as I understand? Again. Mx. GPT reckons this is a few grand, but the architects and Visqueen imply that it'll be non-trivial. Edited September 3, 2025 by Drellingore
saveasteading Posted September 3, 2025 Posted September 3, 2025 1 hour ago, Drellingore said: means sumps and the like Perforated pipe with gravel surround will catch this theoretical gas and vent it. A plastic chamber each end. Radon barrier above. Complexity will vary acc to your construction method. I'd have to check why the radon is expected to somehow get through the barrier so needs venting. A holistic solution shouldn't cost too much. OR. Believe the people trying to sell you stuff. I've built about 60??? Buildings in Kent some very near you, but none needed radon measures. I feel that the sales opportunity/ designer caution has increased over time. I'm unaware of any issues arising in buildings without it...eg most of your neighbours. Can you find out what anyone else locally is doing? That will give you precedent. 1
Drellingore Posted October 29, 2025 Posted October 29, 2025 For those seeking closure: We appointed a company to use a Markus 10 radon-detecting device that can give instant results, but the machine broke and needed to go back to Sweden for repair. We appointed Earth Environmental who put some tubes in the ground, waited a week, collected them, then sent them to a lab. About 12 business days later we got a report back saying there was minimal radon risk and therefore no mitigations are required. Cost was about a grand. 2
saveasteading Posted October 29, 2025 Posted October 29, 2025 3 hours ago, Drellingore said: minimal radon risk Did they give you numbers? Basically was there some radon or none?
dpmiller Posted October 30, 2025 Posted October 30, 2025 8 hours ago, saveasteading said: Did they give you numbers? Basically was there some radon or none? I'll bet on "none" and an easy grand profit.
