Our plans had no depth specified for an oriel window.   We assumed it was to the given scale.  The width and height were specified.
Now we realise it is too small for building regs to be used as an egress window.
Would this be the norm??  That this detail was omitted especially given that the room was intended to be a bedroom and therefore the clear window opening is set out in Building Regs?
Thanks in advance.
Take it up with the architect and get them to update the drawings so it complies.  Unless it is radically different you may not even need to consult the Planning Dept.
Absolutely.  My query is whether it ought to have been there in the first place. I assumed it should have been especially given it was to be the egress window in a bedroom.  He is stating no.
If the plans have been stamped approved I would be surprised if there isn’t a note somewhere in the drawings to describe where an EEW is to be located and the size it needs to be irrespective of what the elevations show.
The whole point of the design was to have a large unbroken pane of glass to show off the view.   The point I am trying to make
1 the room is a bedroom in a bungalow.  This is stated on the plans.
2 All bedrooms must have an egress windown with minimum clear opening widths to meet Building Regs.
3 The depth the side panel was never given on the plans and now we have a big problem.
4 Is it a reasonable expectation that the depth of the side window should have been written on the plans?   Again I stress it was designed as a bedroom and this window was for egress.
You need to play this from where you are and not look to assign blame.  Is there any way the design of the window could be modified to comply with Building Regs?  If you post up a floor plan you may get some useful suggestions.
