revelation Posted May 7, 2025 Posted May 7, 2025 I am struggling to find suitable blocks for my driveway. I have been looking at blocks for my drive, I really don’t like the appearance of concrete paving blocks. Our plan was to lay on MOT/Sand as you would do with normal block paving. I have been advised that stone blocks shouldn’t be laid on sand, and should be on a wet mix. Is there any reason why concrete blocks are ok on sand but not a limestone block?
revelation Posted May 7, 2025 Author Posted May 7, 2025 1 hour ago, nod said: No reason could you elaborate?
nod Posted May 8, 2025 Posted May 8, 2025 8 hours ago, revelation said: could you elaborate? You can bed anything on sand But if your not going to wacker it down level the sand and sprinkle dry cement Prior to laying
ToughButterCup Posted May 8, 2025 Posted May 8, 2025 (edited) 18 hours ago, revelation said: ... stone blocks shouldn’t be laid on sand, and should be on a wet mix. Is there any reason why concrete blocks are ok on sand but not a limestone block? Maybe the advice was given in the context of increasing adhesion of the limestone block. You can - as @nod suggests above - dust some cement on top of the sand before laying, or make a weak mix of cement (only) and water and coat the bottom of the limestone blocks before laying. In simple terms, make the blocks 'stickier' before laying them. I'm edging a path with limestone setts at the moment. I 'butter' each sett before laying it. Bit of water and some cement in a bucket, mix well ( weak gravy ) and drop the sett in that mixture while I'm laying the current sett. I was very surprised to see the amount of 'butter' some of the setts absorb. Occasionally I forget (gone for a coffee) that I've left a sett in the bucket with the cement mixture in it. Half an hour later it's noticeably harder to take the sett out of the bucket. Here's a video of the type of thing I mean ( but a slightly different technique again) Edited May 8, 2025 by ToughButterCup
revelation Posted May 8, 2025 Author Posted May 8, 2025 (edited) Thank you for the information. Doesn’t the video show the blocks being laid on a concrete mix using the cement stuff as a primer? As in my case the plan was to build up the driveway with 150mm of MOT, then sand (all compacted of course) then lay the blocks. Edited May 8, 2025 by revelation
ToughButterCup Posted May 8, 2025 Posted May 8, 2025 17 minutes ago, revelation said: ... As in my case the plan was to build up the driveway with 150mm of MOT, then sand (all compacted of course) then lay the blocks. Yes. I'd call that a dry mix . Not sure everyone would use that term but hey.... you get used to it. Your suggestion above is perfectly OK. A really good reference site for this sort of thing is by a guy who runs this website (Paving Expert) here..... He's a Lancastrian (of course)
Mr Punter Posted May 8, 2025 Posted May 8, 2025 If you don't like concrete (as it is prone to fading and looks like concrete) have you looked at clay paviours? Keeps its colour well and looks good for years.
revelation Posted May 9, 2025 Author Posted May 9, 2025 On 08/05/2025 at 18:35, Mr Punter said: If you don't like concrete (as it is prone to fading and looks like concrete) have you looked at clay paviours? Keeps its colour well and looks good for years. Thanks for the suggestion, they’re super expensive. And look a little better than concrete, but as you’ve suggested they have the longevity factor.
revelation Posted May 9, 2025 Author Posted May 9, 2025 On 08/05/2025 at 16:04, ToughButterCup said: Yes. I'd call that a dry mix . Not sure everyone would use that term but hey.... you get used to it. Your suggestion above is perfectly OK. A really good reference site for this sort of thing is by a guy who runs this website (Paving Expert) here..... He's a Lancastrian (of course) Thanks for the help. Every company who supply the stuff have said no to the idea of laying anything stone on sand. And have all said they must be laid on a cement mix, but didn’t give any sound reasoning as to why concrete blocks are ok but not real stone.
Temp Posted May 10, 2025 Posted May 10, 2025 Scroll down here to the links for Rigid Construction Flexible Construction https://www.pavingexpert.com/setts02
