Spinny Posted April 30, 2025 Posted April 30, 2025 Still waiting on a quote for an oak strip wood soffit for an overhang. Still in two minds about the problem of oak and timber ageing to a grey colour from UV light after a year or two. Therefore also wanting to look at manmade wood effect alternatives that will not change colour and be low maintenance. Any suggestions/suppliers ? Has anyone on here done something similar ? (Slightly wonder if LVT click style planks could be used ?)
nod Posted April 30, 2025 Posted April 30, 2025 I’m just about to build an oak canopy over the front door Staining and going grey is a real problem Osmo UV doesn’t do what it says on the tin Im looking for alternatives I did all our sofits and facias in a would effect Don’t fancy being up a ladder each year 2
Nick Laslett Posted April 30, 2025 Posted April 30, 2025 21 minutes ago, nod said: Osmo UV doesn’t do what it says on the tin So true. My mate recommended Rubio mono coat. 1
nod Posted April 30, 2025 Posted April 30, 2025 17 minutes ago, Nick Laslett said: So true. My mate recommended Rubio mono coat. I’ll give that a try thanks
BadgerBodger Posted April 30, 2025 Posted April 30, 2025 I’m not sure I’ve ever seen oak oudoors, not silver unless regularly treated. Lame goes for larch. And bothe look pretty similar in the end. As a soffit it might well be that as it’s not exposed to uv or weather, it may last a good while. I fitted this (not in wood finish) and the colour 5 years later is still good a strong when exposed to full daylight on a facade… pretty much 0 maintenance. https://www.trespa.com/en_GB/products/wood-decors
