See the sketch. I have the end of an external wall running into the internal area alongside a window.
I am wondering what level of insulation to use across the end of the spur of external wall (where the external wall was cut back to create an opening).
I can use some insulated plasterboard on the inside of the window reveal, but the end of the spur will be plastered over (wet plaster) with the adjacent brick wall. I guess I need a little bit of insulation between it and the plastering to avoid a possible cold spot in a utility room.
Suggestions ?
Thin piece of PIR ?
Something I could spray it with ?
Aerogel matting ?
