junglejim Posted April 5 Posted April 5 I’m cladding my timber frame house using thermo ayous. I’ve tuned boards to make reveals for the windows that butt up against the frame. I’m wondering whether I should run a bead of silicone sealant sling the joint for weather tightness?
Mr Punter Posted April 5 Posted April 5 Silicone probably will not last very long and may discolour. Can you do it without?
junglejim Posted April 5 Author Posted April 5 On 05/04/2025 at 10:08, Mr Punter said: Silicone probably will not last very long and may discolour. Can you do it without? Expand Yes no problem without but wondering what others do?
Russell griffiths Posted April 5 Posted April 5 Leave a gap, it allows it to dry out quicker if it was to get wet. mat risinger did a video on this on YouTube, it was found that sealing up every gap kept moisture in rather than letting it in briefly and out quickly. 2
junglejim Posted April 5 Author Posted April 5 On 05/04/2025 at 12:08, Russell griffiths said: Leave a gap, it allows it to dry out quicker if it was to get wet. mat risinger did a video on this on YouTube, it was found that sealing up every gap kept moisture in rather than letting it in briefly and out quickly. Expand Thanks Russell that’s helpful and exactly what I was wondering.
JamesP Posted April 5 Posted April 5 On 05/04/2025 at 12:08, Russell griffiths said: Leave a gap, it allows it to dry out quicker if it was to get wet. Expand +1. 1
