I'm going to have my ground floor tiled soon and need to let the tilers know what expansion gaps I want then to leave.
I've got 65m² over 3 rooms so was going to get then to fit some expansion joint strips in each of the doorways and a 6mm perimeter gap, does this sound correct? They're modular porcelain tiles onto an anhydrite heated screed.
What about at my external wooden doors, do you leave the same gap as at the wall junctions and fill with a good bead of silicone?
They should really be telling you
10 mil minimum around the perimeter
10-15 mil rubber door joints
Tile up to external doors
Yes they are
The tile supplier will match them to your tiles
Dont get the plastic ones Pay a little more for metal
Edited by nod
3 hours ago, Barnboy said:
Where you tile through an internal doorway how tight do you tile against the door lining ?
I would tile under the door lining personally.  If new build fit door linings after tiling.  If existing cut bottom of door linings off.  Same with skirtings, don't tile up to them, tile up to bare wall with expansion gap left and fit (refit) skirtings to cover perimiter expansion gap.
