CMPW Posted March 5, 2025 Posted March 5, 2025 Hi All, We moved into a house that already had a solar system installed - however we have now found out that the G83 cert (applicable when it was installed) was never registered. The company that installed it has gone out of business so I am trying to apply for the certification myself (so that we can then sign up to one of Octopuses tarrifs). I gather that I would now need to apply for a G98. I have confirmed with SolarEdge that our inverter meets the standards, and I have managed to get the DNO certificate. However, I am finding some of the questions on the UKPN Smart Connect site a bit confusing. I did try reaching out to a couple of local installers - but none seem want to help. Has anyone gone through this process that could give me some advice?
Dillsue Posted March 5, 2025 Posted March 5, 2025 G98 is a notification not an application. How do you know the G83 wasn't registered? Our DNO had no record of our G83 install but admitted that it doesn't necessarily mean they didn't receive it!! If your inverter is an older one that is G83 compliant but not G98, you might run into problems submitting generation a G98??
CMPW Posted March 5, 2025 Author Posted March 5, 2025 Honestly, I don't know if the G83 was registered or not. I am going off the MCS certificate that I have managed to get that says at the bottom "DNO Notification Compliance: To be notified post connection and commissioning", and when I called UKPN they said that they didn't have any details for our house and to fill in the G98. I did contact SolarEdge who confirmed that the inverter is G98 compliant - but honestly feel a bit stuck.
cjsparkey Posted March 5, 2025 Posted March 5, 2025 Not familiar with UKPN G98 form but up here in Scotland the SPN notification form is quite minimal, if you have the MCS cert most if not all the information should be there. Technically the DNO is supposed to be informed before switching on but it’s usually straight forward.
Dillsue Posted March 5, 2025 Posted March 5, 2025 59 minutes ago, CMPW said: Honestly, I don't know if the G83 was registered or not. I am going off the MCS certificate that I have managed to get that says at the bottom "DNO Notification Compliance: To be notified post connection and commissioning", and when I called UKPN they said that they didn't have any details for our house and to fill in the G98. I did contact SolarEdge who confirmed that the inverter is G98 compliant - but honestly feel a bit stuck. That's exactly where we ended up with an MCS cert but the DNO having no record of the install. If SE have confirmed the inverter is G98 compliant then steam on with the notification.
Dillsue Posted March 5, 2025 Posted March 5, 2025 42 minutes ago, cjsparkey said: Technically the DNO is supposed to be informed before switching on but it’s usually straight forward. With G98 it's notification within 30 days after commissioning, so after switching on.
cjsparkey Posted March 5, 2025 Posted March 5, 2025 (edited) 21 minutes ago, Dillsue said: With G98 it's notification within 30 days after commissioning, so after switching on. Useful to know We had to go full G99 (G100) as 6.8Kw and limited export to 3.6Kw due to feeble rural power network. Back to the question @CMPW which bit of the notification is causing the query? Edited March 5, 2025 by cjsparkey
CMPW Posted March 5, 2025 Author Posted March 5, 2025 40 minutes ago, Dillsue said: With G98 it's notification within 30 days after commissioning, so after switching on. We will be well past (years!) that as it was the previous owners that installed the system.
CMPW Posted March 5, 2025 Author Posted March 5, 2025 25 minutes ago, cjsparkey said: Useful to know We had to go full G99 (G100) as 6.8Kw and limited export to 3.6Kw due to feeble rural power network. Back to the question @CMPW which bit of the notification is causing the query? I think I have realised its because I've ticked "don't know" to the DNO cutout rating. Hoping this will be as simple as calling them up and asking them to confirm what it is. I also thought that I had to complete the G100 export limitation section - but re-reading it I realise I can select no to this.
MikeSharp01 Posted March 5, 2025 Posted March 5, 2025 7 hours ago, CMPW said: Has anyone gone through this process that could give me some advice? I when through UKPN G98 as did @Thorfun I think. What was the problem?
Dillsue Posted March 6, 2025 Posted March 6, 2025 (edited) 9 hours ago, CMPW said: I think I have realised its because I've ticked "don't know" to the DNO cutout rating. Hoping this will be as simple as calling them up and asking them to confirm what it is. I also thought that I had to complete the G100 export limitation section - but re-reading it I realise I can select no to this. I don't know what UKPN ask for but the ENA G98 notification that they should be using doesn't ask for the cutout size. Maybe check you're using the correct forms?? The ENA forms are all available on line and it's likely G98 form B you should be using For the export limitation that should be built into a G98 compliant inverter. Are you using an SE3680H inverter or smaller?? Edited March 6, 2025 by Dillsue
CMPW Posted March 6, 2025 Author Posted March 6, 2025 52 minutes ago, Dillsue said: I don't know what UKPN ask for but the ENA G98 notification that they should be using doesn't ask for the cutout size. Maybe check you're using the correct forms?? The ENA forms are all available on line and it's likely G98 form B you should be using For the export limitation that should be built into a G98 compliant inverter. Are you using an SE3680H inverter or smaller?? I have an SE3500H (SOETC/02349/V1/A2) I was filling in the details on the smart connect site - but having looked at the G98 Form B (traditional style) it looks a lot simpler. I will give this a go. Thank you @Dillsue.
Thorfun Posted March 6, 2025 Posted March 6, 2025 9 hours ago, MikeSharp01 said: I when through UKPN G98 as did @Thorfun I think. What was the problem? G99 for us as we’ve got a 10kWp array
MikeSharp01 Posted March 6, 2025 Posted March 6, 2025 12 hours ago, Thorfun said: G99 for us as we’ve got a 10kWp array yes -so Sorry everyone ours was G99, not sure I was think straight yesterday, as well (6kW export Granted on 6kW array) 1
CMPW Posted March 7, 2025 Author Posted March 7, 2025 Under the installer details - would I just put down the details that I have for them even though they are no longer in business (and just leave the signature blank - or just sign in myself!)
markc Posted March 7, 2025 Posted March 7, 2025 2 minutes ago, CMPW said: Under the installer details - would I just put down the details that I have for them even though they are no longer in business (and just leave the signature blank - or just sign in myself!) Put the details you know, you can’t sign as the installer but you could scribble not known etc. that would look like a signature.
MikeSharp01 Posted March 7, 2025 Posted March 7, 2025 You can just be yourself, you don't need to be an installer, they have been instructed to deal with individuals as well as companies. I just told them my name - all worked fine.
CMPW Posted March 7, 2025 Author Posted March 7, 2025 Do you think there will be any push back with the install date being so long ago?
Dillsue Posted March 7, 2025 Posted March 7, 2025 3 hours ago, CMPW said: Do you think there will be any push back with the install date being so long ago? Nope. They're likely greatful that you've bothered to tell them.
CMPW Posted March 13, 2025 Author Posted March 13, 2025 A quick update - I submitted the form on Tuesday and it came back today as approved! Thank you all!
Roger440 Posted March 13, 2025 Posted March 13, 2025 On 07/03/2025 at 13:53, MikeSharp01 said: You can just be yourself, you don't need to be an installer, they have been instructed to deal with individuals as well as companies. I just told them my name - all worked fine. What did you do where it asks for the installers qualifications/credentials? Im going to do a self install, but im not qualified. (well i was, in 1990 under the 16th edition, but i doubt that counts for much!)
Dillsue Posted March 13, 2025 Posted March 13, 2025 The industry(power distribution) is all for best practice and asking for installers details/qualifications sort of drives that but reality is your DNO ain't really interested in what goes on the other side of their cutout/fuse. Thats BC's/part P's domain. For a G98 the system is live so the testing/certification horse has already bolted. For G99 you could be submitting months in advance and not know who your installer will be so quite legit to put N/A or N/K.
Roger440 Posted March 13, 2025 Posted March 13, 2025 4 minutes ago, Dillsue said: The industry(power distribution) is all for best practice and asking for installers details/qualifications sort of drives that but reality is your DNO ain't really interested in what goes on the other side of their cutout/fuse. Thats BC's/part P's domain. For a G98 the system is live so the testing/certification horse has already bolted. For G99 you could be submitting months in advance and not know who your installer will be so quite legit to put N/A or N/K. Interesting. As i intend to do it myself, im sure they wont accept a blank box though however disinterested they might be.. So i have to put something in that box. Question is what? Ill be doing G98.
CMPW Posted March 13, 2025 Author Posted March 13, 2025 1 hour ago, Roger440 said: What did you do where it asks for the installers qualifications/credentials? Im going to do a self install, but im not qualified. (well i was, in 1990 under the 16th edition, but i doubt that counts for much!) I put the name of the company and then "N/A installer no longer trading" in the signature box and left the date field blank. I guess you could just put "Self Install"
MikeSharp01 Posted March 14, 2025 Posted March 14, 2025 8 hours ago, Roger440 said: What did you do where it asks for the installers qualifications/credentials? I don't recall that question on our application, are you using the UKPN online form? I would have said something like this is request for permission to export an appropriate installer will be appointed.
