KJL Posted March 5, 2025 Posted March 5, 2025 Hi l,m a self builder in Cornwall please can anyone give some advice I am thinking of screeding over my first floor 22mm eggerboard structural floor with a 40 mm Anhydrite thermo screed with underfloor heating on top of SNUF super foil.( this for the low build up that I need). first question will this work ( screed man said it would) Any better ideas Could anyone recommend an underfloor heating clip that would go though and hold in the eggerboard? Thanks very much
nod Posted March 5, 2025 Posted March 5, 2025 33 minutes ago, KJL said: Hi l,m a self builder in Cornwall please can anyone give some advice I am thinking of screeding over my first floor 22mm eggerboard structural floor with a 40 mm Anhydrite thermo screed with underfloor heating on top of SNUF super foil.( this for the low build up that I need). first question will this work ( screed man said it would) Any better ideas Could anyone recommend an underfloor heating clip that would go though and hold in the eggerboard? Thanks very much This is one I’m doing for a friend Super easy 10 mil screed to go on the top
Dunc Posted March 5, 2025 Posted March 5, 2025 I don't see why not. Maybe need a bit of plastic down first to stop the screed running through any gaps? Are your joists engineered to take this load? Another alternative is laying the pipes between 25mm battens and surrounding with a dry mix.
JohnMo Posted March 5, 2025 Posted March 5, 2025 Superfoil in that situation will add almost no insulation value. Don't you have acoustic insulation between your joists? That will provide insulation. You could could just do egg crate panels screwed down and the screed over
KJL Posted March 13, 2025 Author Posted March 13, 2025 Thanks very much for all replies. really appreciated . Nod, looks like you have done a great job. please can I ask what diameter underfloor pipe you used? and where you got the clips from. plus what screed are you putting on top of the jack boards. answers to the other questions. yes I will have acoustic insulation between the pozi joists. And I will investigate the egg panel idea.and the pattern and dry mix. cheers
