February 11, 20251 yr Hi All, Need some advise with regards to the manhole cover - As you can see I need a couple of steps from the back door to the garden. My initial thought was the raise the manhole cover and incorporate it into the steps using a recessed cover, however I feel the step would be too large and look silly if I did that. Any other solutions / suggestions would be appreciated. Thanks Joe
February 11, 20251 yr It won't look silly to have a bigger step. The other option is to move the IC further out, but it may be quite a lot of work.
February 11, 20251 yr Without lifting the lid you don’t know what’s below. It will expose your options or lack of them. The lid could possibly be reduced in size and/or rotated/ moved.
