H211 Posted January 16, 2025 Posted January 16, 2025 Hi, I’m an interior designer working on a custom new build which will qualify for zero rating on the VAT, but I have a question about the specifics. The property has two kitchens, the primary kitchen materials can be zero rated, but what about the secondary kitchen? Is it limited to one per property or do they both qualify? The secondary kitchen is in the basement and has a sink, dishwasher, microwave but no ovens etc. I can’t find any specifics on HMRC. Thanks.
IanR Posted January 16, 2025 Posted January 16, 2025 1 minute ago, H211 said: Is it limited to one per property or do they both qualify? If it's on the Planning Approved Drawings, then it's zero rated. If not then HMRC could argue that it's not, but unlikely they would look in that detail. "white goods" are not covered.
Blooda Posted January 16, 2025 Posted January 16, 2025 (edited) Sounds like a utility room to me. 😉 If you [interior designer] are billing the client separate from the kitchen supply your fees will not zero VAT. As @IanR mentions appliances are not zero rated, excepting the extraction hood, [recirculating hoods and extracting hobs are a grey area] . Edited January 16, 2025 by Blooda
Thorfun Posted January 16, 2025 Posted January 16, 2025 22 minutes ago, Blooda said: Sounds like a utility room to me. 😉 If you [interior designer] are billing the client separate from the kitchen supply your fees will not zero VAT. As @IanR mentions appliances are not zero rated, excepting the extraction hood, [recirculating hoods and extracting hobs are a grey area] . does that integrated white goods? like dishwashers, ovens, microwaves etc
IanR Posted January 16, 2025 Posted January 16, 2025 9 minutes ago, Thorfun said: does that integrated white goods? like dishwashers, ovens, microwaves etc Unfortunately not. HMRC makes no distinction between integrated or not. https://www.gov.uk/guidance/goods-and-services-you-can-claim-for-under-the-vat-diy-scheme 1 1
