MikeSharp01 Posted January 8, 2025 Posted January 8, 2025 We need to lay a thin self levelling subfloor, which will then have the wood flooring on it, and I would like to finish the Plaster boarding (PB) before we do the screeding and definitely before we lay the flooring, which I want to be the very last job! I appreciate that I will need to protect the lower portion of the PB, along with doors and windows, up against which the screed will flow from splashes etc. Should I re-think and do the screed first & why?
crispy_wafer Posted January 8, 2025 Posted January 8, 2025 I suppose if you make sure your plasterboards are cut above the floor, so no danger of sucking up moisture then as you say, protect and crack on.
BotusBuild Posted February 15, 2025 Posted February 15, 2025 I guess I'm going to be cutting away the bottom edge of all the plasterboard I've installed 🙂
crispy_wafer Posted February 15, 2025 Posted February 15, 2025 Don’t worry, part of the ahem ‘fun’ going back and doing a bit of rework. It’s how we learn
Conor Posted February 16, 2025 Posted February 16, 2025 15 hours ago, BotusBuild said: I guess I'm going to be cutting away the bottom edge of all the plasterboard I've installed 🙂 No need, we did our boarding first. Polythene dpm and foam edge strips keeps screed away from the boards. 1
