Pocster Posted December 17, 2024 Author Posted December 17, 2024 I sent a photo to a plumbing company … They suggested that if it is welded almost no chance of getting it off . So , cut out a section of the main drain would be easier …. See ! It’s becoming more and more work !
crispy_wafer Posted December 17, 2024 Posted December 17, 2024 Nah not really, get all the bits lined up expecting worst case before you start. Send the wife out to a spa for the day then crack on. You’ll be done and dusted before it’s time for bacon butties. 1
Pocster Posted December 17, 2024 Author Posted December 17, 2024 1 minute ago, crispy_wafer said: Nah not really, get all the bits lined up expecting worst case before you start. Send the wife out to a spa for the day then crack on. You’ll be done and dusted before it’s time for bacon butties. Yeah but first it was a bit of tiger seal. Then it was get the boss off Now it’s cut the (expletive deleted)er out ! Me no likey 🫤
crispy_wafer Posted December 17, 2024 Posted December 17, 2024 3 minutes ago, Pocster said: Me no likey We’ve got faith in you big man! 1
Onoff Posted December 17, 2024 Posted December 17, 2024 If you plan on trying to remove the Tiger Seal of the plastic then it'll be a case of mechanical means first like a wood chisel. To soften the pu try acetone, nail polish remover, carb cleaner etc. The best of British! 1
joe90 Posted December 17, 2024 Posted December 17, 2024 2 hours ago, Pocster said: Well that’s it isn’t it . Start removing this and it’s a one way ticket to fun . Hence me ‘thinking’ about it a lot first … Fair comment but angle grinder with flap disc will make short work of removing plastic IMO. ( I will be there to hold your hand, and only your hand 😳). The glue will only be around the hole surely? 1
Pocster Posted December 17, 2024 Author Posted December 17, 2024 5 minutes ago, joe90 said: The glue will only be around the hole surely? Thats what I said to the girl 1
