Pocster Posted 20 hours ago Author Share Posted 20 hours ago I sent a photo to a plumbing company … They suggested that if it is welded almost no chance of getting it off . So , cut out a section of the main drain would be easier …. See ! It’s becoming more and more work ! Link to comment Share on other sites More sharing options...
crispy_wafer Posted 20 hours ago Share Posted 20 hours ago Nah not really, get all the bits lined up expecting worst case before you start. Send the wife out to a spa for the day then crack on. You’ll be done and dusted before it’s time for bacon butties. 1 Link to comment Share on other sites More sharing options...
Pocster Posted 20 hours ago Author Share Posted 20 hours ago 1 minute ago, crispy_wafer said: Nah not really, get all the bits lined up expecting worst case before you start. Send the wife out to a spa for the day then crack on. You’ll be done and dusted before it’s time for bacon butties. Yeah but first it was a bit of tiger seal. Then it was get the boss off Now it’s cut the (expletive deleted)er out ! Me no likey 🫤 Link to comment Share on other sites More sharing options...
crispy_wafer Posted 20 hours ago Share Posted 20 hours ago 3 minutes ago, Pocster said: Me no likey We’ve got faith in you big man! 1 Link to comment Share on other sites More sharing options...
Onoff Posted 19 hours ago Share Posted 19 hours ago If you plan on trying to remove the Tiger Seal of the plastic then it'll be a case of mechanical means first like a wood chisel. To soften the pu try acetone, nail polish remover, carb cleaner etc. The best of British! 1 Link to comment Share on other sites More sharing options...
joe90 Posted 19 hours ago Share Posted 19 hours ago 2 hours ago, Pocster said: Well that’s it isn’t it . Start removing this and it’s a one way ticket to fun . Hence me ‘thinking’ about it a lot first … Fair comment but angle grinder with flap disc will make short work of removing plastic IMO. ( I will be there to hold your hand, and only your hand 😳). The glue will only be around the hole surely? 1 Link to comment Share on other sites More sharing options...
Pocster Posted 18 hours ago Author Share Posted 18 hours ago 5 minutes ago, joe90 said: The glue will only be around the hole surely? Thats what I said to the girl 1 Link to comment Share on other sites More sharing options...
