26 minutes ago, joth said:
Have you got two-way audio setup with the reollink? I didn't know this was a thing. Apparently Reolink is the main (only?) device supporting it over open protocol (WebRTC, integration via go2rtc)
https://docs.frigate.video/configuration/camera_specific#reolink-doorbell
If your issue is reliability of their wireless chime maybe you can work around it using the visitor event in home assistant to chime a convention hardwired ding dong chime?
https://www.home-assistant.io/integrations/reolink/
For 76 squid their PoE doorbell looks great value. Just lacks the NFC/fingerprint tech vs unifi Protect
2 way audio only through reolink app . Not something I’m too concerned about tbh - usually too slow to be usable .
My issue with the chime is I need it quite far from the doorbell so we can hear it - hence the range issue . So now the chime is as near as possible to the doorbell and yep I get HA to stop any music , make an announcement on Alexa when doorbell pushed . Under test at the moment…
