Selexus Posted November 24, 2024 Share Posted November 24, 2024 Hi Everyone, I'm on the hunt for an ICF deck system suitable for flat roof construction. I'm not able to readily find a UK supplier of this type of this type of system. Can anyone point me in the right direction ? This is the type of thing I'm looking at considering for the flat roof elements of our build. Amdeck: Insulated Concrete Floor and Roof System | Amvic (amvicsystem.com) Cheers. Link to comment Share on other sites More sharing options...
sheelg Posted November 24, 2024 Share Posted November 24, 2024 Hello, I am in search for a solution to do flat roof as well. Our's has a outside deck as well. I know two systems but so far but I am sure others will have more products to suggest : https://thermohouse.co.uk/thermoroof/ https://www.cdi-icm.co.uk/system/op-deck/ I 1 Link to comment Share on other sites More sharing options...
Conor Posted November 24, 2024 Share Posted November 24, 2024 We used thermo house. All good. 1 1 Link to comment Share on other sites More sharing options...
Nick Laslett Posted November 24, 2024 Share Posted November 24, 2024 We also used Thermohouse for our pitched & flat roofs. They also designed and installed the steels for the roof. 1 Link to comment Share on other sites More sharing options...
JohnMo Posted November 24, 2024 Share Posted November 24, 2024 Why not posi rafters? Then either in fill or insulation on top. 1 Link to comment Share on other sites More sharing options...
ChrisJ Posted November 27, 2024 Share Posted November 27, 2024 (edited) There is a product called Insuldeck it is from America, but I understand there is also a manufacturer in Italy and can arrive in the UK in about a 2 week turnaround. I have used the product in Canada and if you are after a concrete decking system I would recommend it. It is similar to Amdeck, however it is one piece length rather then small panels as Amdeck is. Amdeck is not available here, shipping from Canada is possible but costly unless you require an entire container Edited November 27, 2024 by ChrisJ 1 Link to comment Share on other sites More sharing options...
FM2015 Posted November 27, 2024 Share Posted November 27, 2024 Several systems available in France. Link to comment Share on other sites More sharing options...
Selexus Posted November 28, 2024 Author Share Posted November 28, 2024 On 24/11/2024 at 15:23, Conor said: We used thermo house. All good. On 24/11/2024 at 19:08, Nick Laslett said: We also used Thermohouse for our pitched & flat roofs. They also designed and installed the steels for the roof. Having now looked at the Thermofloor option, I'm certainly keen to know more. Was it a straight forward installation (i'm assuming you had ICF walls as well ?) ? Did either of you have any additional structural strengthening required ? possibly over large window or door opening ? I need this and am keen to understand if any flex in the roof/deck is present ? I'm sure our SE will want to specify additional steel to support our main 12m openings. How were Thermohouse to deal with ? Delivered on time? good support? Thanks Link to comment Share on other sites More sharing options...
