Markca Posted November 23, 2024 Share Posted November 23, 2024 Hey all, our upstairs UFH isn’t working atm and I’m pretty sure it’s because of this leak. is it easy to sort? Is it a particular washer that I’ll need or will it need new parts? Link to comment Share on other sites More sharing options...
Markca Posted November 23, 2024 Author Share Posted November 23, 2024 I should add, I tried tightening it and it didn’t help Link to comment Share on other sites More sharing options...
FuerteStu Posted November 23, 2024 Share Posted November 23, 2024 Not sure if that drip would stop the whole system from working. But that isolator valve in closed position might. Can we see the whole setup? Maybe a drawing of what is where? Link to comment Share on other sites More sharing options...
ProDave Posted November 23, 2024 Share Posted November 23, 2024 34 minutes ago, FuerteStu said: But that isolator valve in closed position WOULD Corrected that for you 1 Link to comment Share on other sites More sharing options...
Markca Posted November 23, 2024 Author Share Posted November 23, 2024 1 hour ago, FuerteStu said: Not sure if that drip would stop the whole system from working. But that isolator valve in closed position might. Can we see the whole setup? Maybe a drawing of what is where? Well yes, that would definitely stop it 🤣 that’s why I turned it to that so it wasn’t leaking all night! photos coming shortly 50 minutes ago, ProDave said: Corrected that for you Link to comment Share on other sites More sharing options...
ProDave Posted November 23, 2024 Share Posted November 23, 2024 So is it a bad leak not just an occasional drip? Link to comment Share on other sites More sharing options...
Markca Posted November 23, 2024 Author Share Posted November 23, 2024 55 minutes ago, ProDave said: So is it a bad leak not just an occasional drip? It was dripping a fair bit. I tightened it but it only slowed it down, not stop it. Link to comment Share on other sites More sharing options...
Markca Posted November 23, 2024 Author Share Posted November 23, 2024 The boiler. Under the stairs on the ground floor Link to comment Share on other sites More sharing options...
Markca Posted November 23, 2024 Author Share Posted November 23, 2024 Downstairs manifolds and pump. About 5 metres from the boiler in a cupboard Link to comment Share on other sites More sharing options...
Markca Posted November 23, 2024 Author Share Posted November 23, 2024 Also in the cupboard Link to comment Share on other sites More sharing options...
Markca Posted November 23, 2024 Author Share Posted November 23, 2024 Upstairs manifolds Link to comment Share on other sites More sharing options...
