skysnowinguk Posted November 22, 2024 Posted November 22, 2024 hello been quote £6500 for the below work on a dormer repair in Surrey. is it a fair quote? thank you Scaffolding; Remove and dispose fibre slate from dormer; Remove and dispose rotting wooden fascia and plastic vents which are hanging down; Supply and install new PVC fascia and vented soffit; Supply and install breathable membrane on dormer and treated 25 x 50 batten; Supply and install lead flashings to dormer cheeks; Supply and install natural slates to dormer.
ProDave Posted November 22, 2024 Posted November 22, 2024 I can't comment if the quote is fair. BUT I see no mention of insulation. So I would stop and think what you want. Dormers, particularly old ones are poorly built and poorly insulated. If you are going to the trouble of replacing rotten cladding, I would first stop and think is that all you want to do, or would you rather use the opportunity to upgrade it more and make it a much better insulated space, quite possibly for little extra cost compared to just re cladding it? 1
Russell griffiths Posted November 22, 2024 Posted November 22, 2024 How can we tell without a picture or a set of plans is it just 2 sq m or 200. 🤷🏻♂️
skysnowinguk Posted November 22, 2024 Author Posted November 22, 2024 thank you. adding insulation is a great idea. will certainly take the opportunity to add the insulation.
skysnowinguk Posted November 22, 2024 Author Posted November 22, 2024 the size is about 2 meters by 2 meters
