Bournbrook Posted yesterday at 15:29 Share Posted yesterday at 15:29 Hi. We are going to be building a new house in the garden of current house starting next year. However we are keen to demolish a garage in the current garden. Although this was part of planning we could obviously do this anyway without planning permission. if we do this, would the development have officially started? Obviously we could do this completely separately to our actual house development, so I’m not sure where we stand. any info welcome. Thanks. Link to comment Share on other sites More sharing options...
nod Posted 23 hours ago Share Posted 23 hours ago Check with your Cil Ours said we where ok Stripping the slates off the roof But nothing else No heavy machinery Diggers etc Link to comment Share on other sites More sharing options...
Bournbrook Posted 22 hours ago Author Share Posted 22 hours ago 1 hour ago, nod said: Check with your Cil Ours said we where ok Stripping the slates off the roof But nothing else No heavy machinery Diggers etc Thank you. I have checked all documents and can’t see anything. Do you know which particular form? Link to comment Share on other sites More sharing options...
nod Posted 21 hours ago Share Posted 21 hours ago It wasn’t a form For both builds I contacted the Cil by phone They where quite clear Cut trees and clear the plot Remove slates but not joists No heavy machinery On our second build the SE required test holes I contacted them again and asked about taking a mini digger on There response was that I could take a full size digger on But leaving it there Or storing it onsite would constitute a commencement Im not sure if the Cil applies to you But that’s the main one Planners are more likely to tell you to stop what you are doing and that’s pretty much it Unless there’s a complaint It’s unlikely anyone will know Except All of BH 😁 1 Link to comment Share on other sites More sharing options...
DevilDamo Posted 21 hours ago Share Posted 21 hours ago If it is noted on the approval, you could demolish it and then submit a Lawful Development Certificate application for an existing use. That will then confirm commencement. But before any works start, make sure that any pre-commencement conditions or CIL requirements have been dealt with first. Link to comment Share on other sites More sharing options...
nod Posted 21 hours ago Share Posted 21 hours ago Just to add The cil can be sleeted out over the phone Within a couple of days Link to comment Share on other sites More sharing options...
Bournbrook Posted 20 hours ago Author Share Posted 20 hours ago 47 minutes ago, DevilDamo said: If it is noted on the approval, you could demolish it and then submit a Lawful Development Certificate application for an existing use. That will then confirm commencement. But before any works start, make sure that any pre-commencement conditions or CIL requirements have been dealt with first. Thank you. That’s why I’m trying to ascertain whether cutting back hedges and taking down a garage would be classed as development as we still have outstanding pre commencement conditions to clear. Link to comment Share on other sites More sharing options...
DevilDamo Posted 20 hours ago Share Posted 20 hours ago You will not be able to justify commencement without discharging any conditions or requirements first. Otherwise, you’d be in breach of Planning and open to enforcement action. Link to comment Share on other sites More sharing options...
Bournbrook Posted 19 hours ago Author Share Posted 19 hours ago 30 minutes ago, DevilDamo said: You will not be able to justify commencement without discharging any conditions or requirements first. Otherwise, you’d be in breach of Planning and open to enforcement action. Hence the title of this post. Trying to ascertain if cutting back hedges (which we could without planning as part of gardening) would count as ‘commencement’ Link to comment Share on other sites More sharing options...
DevilDamo Posted 19 hours ago Share Posted 19 hours ago No, that would not meet the definition of commencement. And even if it did, you would still need to discharge any pre-commencement conditions or requirements first. Link to comment Share on other sites More sharing options...
G and J Posted 16 hours ago Share Posted 16 hours ago We’re facing a similar question for our build. We’ve both a garage and a bungalow to demolish. We’re going to declare a start to the CIL team (ours are lovely and helpful on the phone) before we do anything but shrub clearance. The CIL team were happy that we declared a start way too early - their attitude was better too early than too late. It’s a similar thing with our party wall agreements, we’ll be notifying of a start well before the main demolition event takes place, but there’s lots of prep to do and we don’t want to risk an accusation of starting before giving notice. We cleared trees before planning was granted, which was a good thing. Site insurance is a consideration. We’re currently insured as an empty house till mid January, and may well start site insurance then rather than renew. But that means we are wary about doing stuff that would be questionable re the house insurance before then. With any luck, we’ll have building regs approval and planning conditions sorted by mid Jan and can start demolition after that knowing we’ve got our ducks in a row. Link to comment Share on other sites More sharing options...
Alan Ambrose Posted 6 hours ago Share Posted 6 hours ago >>> There response was that I could take a full size digger on But leaving it there Or storing it onsite would constitute a commencement BTW these detailed rules are made up by the LPA (and therefore different between LPAs) - they’re not in the statute. So, you could argue them in court if you need. Link to comment Share on other sites More sharing options...
G and J Posted 6 hours ago Share Posted 6 hours ago 26 minutes ago, Alan Ambrose said: >>> There response was that I could take a full size digger on But leaving it there Or storing it onsite would constitute a commencement BTW these detailed rules are made up by the LPA (and therefore different between LPAs) - they’re not in the statute. So, you could argue them in court if you need. I prefer my cheaper and lower stress approach based on a phone call. The CIL thing is only one consideration, but you might find your area’s CIL people are just as helpful as East Suffolk. Remember to smile when you call ‘em. That smile does somehow make it to the other end of the line. Link to comment Share on other sites More sharing options...
