Andyh747 Posted November 5 Share Posted November 5 Hi all, I've had a Rewatec Solido gravity system installed since 2016 with no issues since installation. However the system stopped operating recently and I traced the fault to the blower (Hiblow XP-60). I've replaced the pump and that is now working fine. However a second fault has been identified which is a faulty solenoid coil on the air distribution manifold. I'm in contact with the manufacturer/supplier Premier Aquatech but struggling to get a replacement solenoid coil - they've changed the system and mine is an older version. A very long shot here but does anyone have any spare solenoid coils which will fit this system? I've attached a photo of the system and the coil. Before anyone asks if I've confirmed the coil is faulty I have. I tested resistance and also swapped the coils around which confirmed the coil is not working. I could use an alternative solenoid valve assembly and bypass the manifold but would prefer to just replace the faulty coil. Thanks for any help as we're currently without an operating plant. Link to comment Share on other sites More sharing options...
crooksey Posted November 5 Share Posted November 5 Isn't this just a normally/open closed solenoid coil? Link to comment Share on other sites More sharing options...
Andyh747 Posted November 5 Author Share Posted November 5 (edited) Yes but it is specifically designed to seal onto the manifold. There's a protruding ring on the base of the coil which seats onto the manifold. I can't find a match anywhere. Edited November 5 by Andyh747 Link to comment Share on other sites More sharing options...
dpmiller Posted November 5 Share Posted November 5 built-up heads like that are more common on hydraulics, I think. Can you get piccys of the whole manifold assy- are the 3 valve just bushed together or is it a single base? what's the thread size of the hose fitting? Link to comment Share on other sites More sharing options...
Andyh747 Posted November 5 Author Share Posted November 5 I've attached another couple of photos. One was taken while I was cleaning the manifold. If you need more let me know. It's a single base and each coil has a spring loaded valve which is normally closed to seal that port. When commanded the valve opens allowing air through the correct hose. Link to comment Share on other sites More sharing options...
dpmiller Posted November 5 Share Posted November 5 trying to get hold of someone in HEB would be a direction I'd think? Don't seem to have a website tho Link to comment Share on other sites More sharing options...
dpmiller Posted November 5 Share Posted November 5 here https://shop.yoviro.com/produkte/magnetventile/1032/luftverteilerleiste-3-fach-mit-anschlusstuellen?number=00020020 Link to comment Share on other sites More sharing options...
Andyh747 Posted November 5 Author Share Posted November 5 Already tried that but the company which supplies these is Premier Aquatech but they've had to go back to the parent company in Germany and it's taking ages to get any information hence my post to see if anyone had a spare lying around 🤣 Link to comment Share on other sites More sharing options...
Andyh747 Posted November 5 Author Share Posted November 5 Just now, dpmiller said: here https://shop.yoviro.com/produkte/magnetventile/1032/luftverteilerleiste-3-fach-mit-anschlusstuellen?number=00020020 That looks like it - great find. Pity I have to buy the whole thing though. Only need the coil. However if it's the only option then so be it. Link to comment Share on other sites More sharing options...
dpmiller Posted November 5 Share Posted November 5 they do a single valve at 137€ too, but that's not dear really Link to comment Share on other sites More sharing options...
ProDave Posted November 5 Share Posted November 5 What diagnostics have you done to confirm it is the solenoid coil that is faulty? It could the signal that is driving it that is not present? It could be it is energising but the thing it is activating is stuck. Link to comment Share on other sites More sharing options...
Andyh747 Posted November 5 Author Share Posted November 5 Just now, ProDave said: What diagnostics have you done to confirm it is the solenoid coil that is faulty? It could the signal that is driving it that is not present? It could be it is energising but the thing it is activating is stuck. Did you read my initial post? I've tested the coil with a resistance meter and swapped the coils around. It's open circuit on test. Link to comment Share on other sites More sharing options...
Andyh747 Posted November 6 Author Share Posted November 6 After a lot of effort I’ve managed to source replacement coils in the UK. A company called MJ Abbott Ltd in Wiltshire has them in stock. I’ve ordered two to keep a spare. I also ordered a replacement diffuser as the old one could do with changing. Just thought I’d update this thread in case anyone else ever comes across this issue and needs to source replacements. Thanks for the helpful comments and links provided. 1 Link to comment Share on other sites More sharing options...
