Fire proofing
It’s usually But can be done with two walls together with a minimum of 50 mil void with fire stops along the perimeter  But can be done single (Shaft  wall) Needs to be done in none combustible MF or masonry
If it’s in a void loft ceiling etc It can be done with a curtain
18 hours ago, ETC said:
The wall between an attached garage and a dwelling and a wall between a pair of semi-detached houses would be domestic examples of a compartment wall.
So a part wall is technically a compartment wall?
