OldieNewbie Posted November 2, 2024 Posted November 2, 2024 Hi all, Could anyone tell me what is a Firewall? What is Compartment Wall? Is there a difference? Thanks 😊
Mike Posted November 2, 2024 Posted November 2, 2024 A firewall is a generic term. A compartment wall is a fire-resistant wall that subdivides a building into separate sections. 1
nod Posted November 2, 2024 Posted November 2, 2024 It’s usually But can be done with two walls together with a minimum of 50 mil void with fire stops along the perimeter But can be done single (Shaft wall) Needs to be done in none combustible MF or masonry If it’s in a void loft ceiling etc It can be done with a curtain 1
ETC Posted November 2, 2024 Posted November 2, 2024 The wall between an attached garage and a dwelling and a wall between a pair of semi-detached houses would be domestic examples of a compartment wall. 1
nod Posted November 2, 2024 Posted November 2, 2024 I do hundreds of these each year Lots of variation
OldieNewbie Posted November 3, 2024 Author Posted November 3, 2024 18 hours ago, ETC said: The wall between an attached garage and a dwelling and a wall between a pair of semi-detached houses would be domestic examples of a compartment wall. So a part wall is technically a compartment wall?
ETC Posted November 3, 2024 Posted November 3, 2024 2 hours ago, OldieNewbie said: So a part wall is technically a compartment wall? Yes.
