Alwayslearning22 Posted October 13 Share Posted October 13 Hey folks I had a Upvc door replaced as it was “bowed” and wasn’t compressing against the frame enough to seal it. I’ve just noticed my new door has exactly the same issue as the old door. I’m wondering now is it a fitting issue instead of a faulty door. It’s tight at the top and bottom but not in the middle. I’ve cam rollers adjusted fully tight but the new door still isint compressing tight enough. I find it odd that the new door has an identical problem to the old one. Anyone know if this is an easy fix? p Link to comment Share on other sites More sharing options...
ProDave Posted October 13 Share Posted October 13 Are you sure it is not the frame that is bowed? Link to comment Share on other sites More sharing options...
Alwayslearning22 Posted October 13 Author Share Posted October 13 I don’t have a long enough level to check it. Is it possible that a new door frame is bowed? Would it be caused by poor fitting? thanks Link to comment Share on other sites More sharing options...
