Duncan62 Posted September 27, 2024 Posted September 27, 2024 Hello all, my SE has washed their hands of the woodfibre and cladding fixing details. So I've come up with some myself, and would like a critique - or explain what you did for a similar build please? Reading around, it looks like 45 degree fixings help to ensure there isn't any "sag" in the woodfibre/cladding due to the weight? Stainless steel Screws for corrosion resistance? Buildup: 300mm IBEAM (on 600mm centers) 18mm OSB 60mm Woodfibre House Wrap/membrane 25x50mm vertical batten 45x45mm horizontal batten Vertical thermowood cladding Prelim Woodfibre Fixing Schedule: Advice greatly appreciated!
Iceverge Posted September 27, 2024 Posted September 27, 2024 That schedule looks fine although theres no need for the screws angled downwards I would say. Do you have a plan to hit the studs through the membrane and woodfiber with screws? It might be worth getting someone to do the calcs on it as it looks almost over screwed. Every screw saved might be up to £1 inc your labour. 1
Duncan62 Posted September 27, 2024 Author Posted September 27, 2024 38 minutes ago, Iceverge said: That schedule looks fine although theres no need for the screws angled downwards I would say. Do you have a plan to hit the studs through the membrane and woodfiber with screws? It might be worth getting someone to do the calcs on it as it looks almost over screwed. Every screw saved might be up to £1 inc your labour. Studs are 88mm wide. We have all the dims for stud location - so hoping that is sufficient to find them! 1
Duncan62 Posted September 27, 2024 Author Posted September 27, 2024 Having searched - Fastener Types will be: GREEN 8.0 x 140mm T40 Spax Extra Long Washer Head Wood Screw, Stainless Steel RED / BLACK 8.0 x 180mm T40 Spax Extra Long Washer Head Wood Screw, Stainless Steel A2
Mr Punter Posted September 27, 2024 Posted September 27, 2024 I don't understand the 45 deg angled screws. With the washer head they won't even sit nicely. 1
ADLIan Posted September 27, 2024 Posted September 27, 2024 Spax do similar in warm, pitched roofs. Rather than fixing being only in bending, due to vertical load, through thickness of the insulation it’s also part in tension. Makes perfect sense. Good fixings. 1
Duncan62 Posted September 28, 2024 Author Posted September 28, 2024 15 hours ago, Mr Punter said: I don't understand the 45 deg angled screws. With the washer head they won't even sit nicely. Screws at 45 Deg will be behind the external closing so will not see them. Screws at 45 Deg take the weight of the woodfibre from sagging/bending the horizontal fasteners. I could change the 45deg ss flat head screw to a ss normal counter sink head instead.
