Flat GRP Roof damage and temporary repair question
So we have a roof that isn't actually flat, it's faceted in triangles. It's board, fibreglass, then GRP (as far as I know). There are a few spots where the GRP seems to have flaked/been scratched away - could be bird claws, sun exposure - the surface is 5 years old. I don't know what the cause is. We noticed a leak in one area and I'd covered that with a tarpaulin and that seemed to have basically stopped the leak. We're coming into winter and it will get windier and so I was looking to temporarily fix it using something like Tekcryl or something similar, a fibreglass based repair paint sort of thing.
Now this is temporary for the winter, when it comes into next year then I would look at getting the roof done properly.
I've never used this stuff before and I don't know enough about GRP roofs to say whether this would work - so I'm hoping for some advice. Would this work for 6 months or so? Is there something better?
Any help really appreciated!
thanks
Paul
I took these before popping some tarpaulin up. I've done some reading and perhaps the coating wasn't done properly in the sense maybe it went up with the boards under being damp. I'd read that can cause peeling problems but really this looks like flaking and bird claws scratching away. Could be wrong!
thanks
Paul
If that’s the boards we can see then it’s not grp, even laid over wet boards grp would be a hard rigid layer that is pretty bomb proof - think of a fibreglass boat or kit car. I reckon you have some sort of fabric with a paint or resinous coating. As above, it really needs sorting or it is likely to peel off.
I have every intention of sorting it properly but realistically I'm not going to get a chance until after this winter. So for the most part the roof is fine, but there are some parts that need something. So hence the question whether I can apply something like tekcrly or in fact I'm being pushed some gorilla sealing tape which sounds like it would do the job. Like a quick sand down and apply - before the weather gets really bad. Most of these solutions say they work quickly and in the damp.
Interesting you say it may not be GRP because from memory I am pretty sure that's what I was sold. I will need to go back to the original documents to see. If not GRP what would you guess it was?
@PCurtis for a quick fix you could use a tanking/liquid membrane - Aquaseal or similar, goes on like thick paint and cures to a flexible rubber like layer. You can apply to damp surfaces (cellar walls etc. but much better if it’s dry - heat gun or hair dryer work well).
Looks suspect for sure. For a quick fix, rub it down and pour / roller a couple coats of GRP topcoat resin. Make sure it's dry and not too cold.
On 28/09/2024 at 06:03, SteamyTea said:
It is almost certainly a mismatch between the base resin used with the glass fibre and the top coat.  should not be a problem structurally, but then it should not be leaking.
The easy way to fix it is to use a polyurethane coating.
Something like this.
https://www.topseal.co.uk/topseal-pu/
This looks good, although that's a proper solution as the stuff can't be bought, need to find a contractor - so perhaps for next year - thanks!
This sounds ideal for right now, should get me out of a fix... thanks!
