Morning everyone. I could do with a bit of guidance on how to lay the roofing membrane into a lead valley. I’ve searched the internet and can’t seem to find anything that is clear. Any help would be appreciated.
Thanks
Col
You need A1f building paper This will stop the lead from sweating
At £70 a roll many roofers will just Chuck a length of membrane in there
But if you are going to do that you may as well use the cheap plastic valleys that all the mass produced houses are now using
Thanks a lot. So that goes between the roofing membrane and the lead?
Directly onto your timber valley
2 hours ago, Co1 said:
Then the membrane over the top, and then the lea
lead directly on the paper Then curl the edge of the membrane under the slate
Thanks a lot. Much appreciated.
don,t forget to fit the lead valley in lengths --NOT one piece
about 1.5m each bit and overlap  them
this will stop any problems from expansion of the lead  when roof is hot
also easier to get a long valley looking good
