Does anyone know where I should be looking to add additional screws to sure up some squeaky flooring on my stairs?
Removed all the carpet and underlay today, ready for some decorating and a floor runner.
However I'd like to try and address a few squeaks and creaks before getting on with that!
I can't access under the stairs, so need to address from what can be seen in the photo.
Cheers
Unfortunately it’s under the stairs that remedial work needs doing, tightening wedges (the wood shrinks with age and the wedges become loose ) also additional blocks can be added. Why can you not access under the stairs?
It's all boarded up and decorated finish, the space under the stairs has pull out drawers and a cupboard. Oh dear!
On the bright side, knowing this, at least I'll not waste time or screws attempting to fix it from this side.
Edited by AChristie
Fixing from the top with screws might actually make things worse. As you won't know if you're forming gaps by pushing the wood sections apart.
In that case I'll definitely leave it as is, there's only a couple of loose creaks here and there.
I'll know for next time!
Cheers guys.
