Dave Jones Posted July 16, 2025 Posted July 16, 2025 get the roll of electric cable before you dig and lay it as you go. if you have bends it will 100% snag in that horrible felxi duct. Otherwise use sewer pipe instead of the flexi and it will be a breeze to pull through.
Temp Posted July 16, 2025 Posted July 16, 2025 2 hours ago, Dave Jones said: Otherwise use sewer pipe instead of the flexi and it will be a breeze to pull through. I was told our electric co was fussy about ducts and it had to be a smooth bore solid wall pipe printed with some standard on the outside (at least for the bit from road to house).
Mr Punter Posted July 16, 2025 Posted July 16, 2025 6 hours ago, Temp said: I was told our electric co was fussy about ducts and it had to be a smooth bore solid wall pipe printed with some standard on the outside (at least for the bit from road to house). +1 and the DNO do not allow you to run electric through sewer pipe or non approved ducting. 1
kandgmitchell Posted July 16, 2025 Posted July 16, 2025 7 hours ago, Temp said: I was told our electric co was fussy about ducts and it had to be a smooth bore solid wall pipe printed with some standard on the outside (at least for the bit from road to house). Mine certainly was - I had to search hard to find the larger duct for their three phase cable as only a few places kept it in stock
