junglejim Posted July 24, 2024 Posted July 24, 2024 Should joints between panels be taped? I’ve read contradicting advice in this. Thinking specifically about the roof at the moment but figure it’s relevant all over? Thanks
Mr Punter Posted July 24, 2024 Posted July 24, 2024 1 hour ago, Russell griffiths said: Panels of what. SIPS OSB I assume.
junglejim Posted July 24, 2024 Author Posted July 24, 2024 1 hour ago, Mr Punter said: SIPS OSB I assume. Yes correct SIPS OSB panels
Redbeard Posted July 24, 2024 Posted July 24, 2024 Is the OSB your air-tightness layer, or is that dealt with by a separate membrane? If the former, yes, tape. If the latter, maybe not. (Unless you are a serious pessimist and decide to do both!)
junglejim Posted July 25, 2024 Author Posted July 25, 2024 21 hours ago, Mr Punter said: SIPS OSB I assume. Yes correct SIPS OSB panels 19 hours ago, Redbeard said: Is the OSB your air-tightness layer, or is that dealt with by a separate membrane? If the former, yes, tape. If the latter, maybe not. (Unless you are a serious pessimist and decide to do both!) Thanks. Good question. I’ll need to check with the TF company. Presumably internally needs to be taped or sealed in that case and external left untaped?
Redbeard Posted July 25, 2024 Posted July 25, 2024 10 minutes ago, junglejim said: Presumably internally needs to be taped or sealed in that case and external left untaped? Difficult to answer without knowing the SIPs designer's rationale/strategy, but yes, the bottom one could be the combined a/t and vapour-check plane. Although of course a/t layers can be external...
markocosic Posted January 6 Posted January 6 I'd do both. Avoids air going through SIP joints if there a compromise in the VCL. It isn't that much tape in the grand scheme of things.
cheekmonkey Posted August 11 Posted August 11 all our panels were foamed together during build. the sole plates & top plates were siliconed as were all the internal roof joints & eaves. i didnt bother internally taping anything or running a VCL inside. OUtside was thermally wrapped & i did tape that although not sure it adds much. Key is making as few holes in the structure as possible & if you do foaming & siliconing them carefully (spec window openings & where any pipes enter/ leave). Our place is very very stable temp all year & pretty good air tightness without any of the internal taping. if you did tape inside as well then you could achieve passive standards pretty easily in my opinion
