Hi, I believe some water got down below the screed and is trapped between the slab and screed where the insulation is.  A bad smell comes up around where the soil pipes go through the screed and I also believe around the edges of the screed and gets up behind the plasterboard and into the ceiling.
I'm planning on drilling a 6cm diameter hole down through the screed so I can check out if there is damp down there causing a bad smell.  If there is damp under the screed I plan to probably suck air through the hole to help dry it out.
Is there anything I should be careful of when drilling a 6cm diameter hole down through my screed ?
Thanks
Stephen
I would first pressure test the drains, to ensure the "damp" and smell is not being caused by a leak in the drains somewhere.
Thanks
Stephen
it would dry out. CCTV inspection of the drains first. Cheap endoscope camera on ebay
