stevela Posted July 8, 2024 Posted July 8, 2024 Hi, I believe some water got down below the screed and is trapped between the slab and screed where the insulation is. A bad smell comes up around where the soil pipes go through the screed and I also believe around the edges of the screed and gets up behind the plasterboard and into the ceiling. I'm planning on drilling a 6cm diameter hole down through the screed so I can check out if there is damp down there causing a bad smell. If there is damp under the screed I plan to probably suck air through the hole to help dry it out. Is there anything I should be careful of when drilling a 6cm diameter hole down through my screed ? Thanks Stephen
ProDave Posted July 8, 2024 Posted July 8, 2024 I would first pressure test the drains, to ensure the "damp" and smell is not being caused by a leak in the drains somewhere.
Dave Jones Posted July 8, 2024 Posted July 8, 2024 39 minutes ago, stevela said: Hi, I believe some water got down below the screed and is trapped between the slab and screed where the insulation is. A bad smell comes up around where the soil pipes go through the screed and I also believe around the edges of the screed and gets up behind the plasterboard and into the ceiling. I'm planning on drilling a 6cm diameter hole down through the screed so I can check out if there is damp down there causing a bad smell. If there is damp under the screed I plan to probably suck air through the hole to help dry it out. Is there anything I should be careful of when drilling a 6cm diameter hole down through my screed ? Thanks Stephen it would dry out. CCTV inspection of the drains first. Cheap endoscope camera on ebay
saveasteading Posted July 8, 2024 Posted July 8, 2024 What is the construction? Screed type, thickness. Dpm? Insulation Dpm . Sub base?
