On 25/07/2024 at 14:23, Iceverge said:
390mm is the depth I'm adding up here from the plasterboard to the membrane on top.
How about this.
Or a hybrid warm roof as shown below with 150mm above the rafters and 100mm between. You'd need to tape the bottom layer of OSB as airtightness here.
Also. Is the osb below the pir needed or is this for racking strength? If I wasn’t using this osb as my vcl would it need to be there? Vcl would go below mineral wool in this option.
Edited by Rishard
Okey dokey....
Got a chance to read back through the thread.
QUESTIONS!
1. What U value do you NEED?
2. What U value do you WANT?
3. Can you source blown cellulose?
4. Can you provide a cross section and plan of the attic.
In an ideal world I would opt for completely pumped/blown insulation every time. Our precious humanity is to short to be wasted on chopping and breathing in insulation. Failing this complete boards of rigid insulation outside the timbers are my preference over inside.
I wouldn't build another roof without a layer of rigid sheathing. Sarking boards, OSB, or woodfiber. An unsupported breather membrane is too vulnerable to rodent, bird and wind damage. We didn't sheath our roof and it's something I'd change.
Airtighess is precisely one billion times more important than U value. This only works if it's planned from day Zero and easy to execute.
I don't like exotica for building houses. Preferably everything should come from the local BMs. That said you may have I-joists avail locally?
Anyone who mentions the word "breathable" almost certainly doesn't know what they're talking about and definitely doesn't understand it's role Vs airtightness & windtightness.
Just to be clear @Iceverge because I massively respect your input and opinions here, and you’ve helped on so many aspects of my build.. are you saying that interstitial condensation is NOT a consideration and having vapour permeability is NOT a requirement if a near perfect level of interior airtightness is achieved? Not even as a belt and braces approach?
Ok. My plans were submitted pre the last building regs change. Going from 0.13 to 0.11 ( from a quick google) In my phpp I have it at 0.104. Anywhere below 0.11 would feel satisfying. Although from some of your previous messages, the real terms difference of these uvalues may not have to drastic a cost implication from a heating perspective.
I have had a quote for blown cellulose which is promising. It does come in as the most expensive option currently. Plus the additional cost of Ibeams or using local stock with extra additional timber screw on.
My current favourite option is
170mm rafters
180mm mineral wool
100mm pir below rafter.
Vcl
25mm service void
plasterboard.
All locally available and altogether come in cheaper than the supply/install of cellulose.
I could take my rafters down to 145mm minimum if needed. I’ve been in circles with this, as you may see. Flipping the above option presents a ‘condensation risk’ in my calc. Leaving it this way does have some small thermal bridges at the ridge and the wall - roof junction where the insulation thins a little around the birds mouth connection at the wall plate. Gauging which of the 2 small compromises is better or worse is where I’m at now.
No doubt there are multiple other options. I’ve priced all the cellulose/wood fibre/ mineral wool/ pir / hybrid / warm options. The more layers I add seems to add either cost and or complexity. What’s the saying, keep it simple stupid? If only 😅
My original architects plans are fairly lose but generally it shows 200mm pir between with 25mm under. I think we both knew at the time it wasn’t going to be this but gave us enough to put it through planning.
The roof will all be hand cut with a gluelam ridge beam. All vaulted. There is some adjustment on wall plate heights if I need to favour a warm roof. And 145mm rafters would tick the box for my spans.
  • 1 month later...
170mm rafters
180mm mineral wool
Vcl
25mm service void
plasterboard.
Some really useful info in here. What span did you achieve with the gluelam beam? I have 2 ridges, both 15m long and I've keen to avoid steels.
You can make box beds or filch beams on site too.
What's your roof design and I'll feed it I to chatGPT
Thanks, I'm not sure how much detail you need? I don't have any technical drawings yet. The span on the ridge between the front and rear gables is 15m.
My longest ridge beam is only 6m. I’ve used glue lam throughout as I love the look of it. I’m actually lifting them up tomorrow so I’ll get some pictures. I also built a gluelam truss just to give a bit of a wow factor as it’s above the main enterance at full height from ground floor to the ridge. I actually joined a couple of glue lams, they join on a masonry wall. That beam is now 10m long. My supplier could supply up to 15m I think but I would struggle to lift my beam in at 10m. My engineer calculated my beams and I basically doubled the height mainly for aesthetics. I think I could have gone deeper still.
Here are a few pics: IMG_7849.thumb.jpeg.b47081c684f8916f1164ff6a21fac7de.jpeg4B939547-9D82-4DCC-826E-2471CD58B80E.thumb.jpeg.f56a60fe3531434653c819a7b68cec2d.jpegIMG_7851.thumb.jpeg.1545f2a9a8271fc0901c139f2d053a10.jpeg
It’s dpc. It will tape into my vapour control layer once the osb is attached to the ceiling. I was just going to tape the vcl to the beam but figured this would be a lot easier.
There is a ridge board above the glue lam which the rafters are all fixed to so there are no holes in the dpc. It’s also stuck down with airtightness silicone. Would have used a ‘smart’ membrane similar to the vcl which I’ll be using but didn’t have any to hand. Felt the dpc would be better than a roofing membrane out of the 2 available materials to hand.
Edited by Rishard
