Hi,
I'm about to come to the part in the landscaping build where I will have lots of MOT Type 1 subbase to shift and rake into position. My previous garden rake broke so looking for something up to the job. Is there something with a normal rake on one side and builders rake on the other?
Cheers
+1 for steel tarmac rake; they're built to last.  Shovel the type 1 as much as possible or you end up raking the big stuff out and leaving the fines that bind it behind.
Yes I realised that raking MOT type 1 doesn’t work the first time I did it. In the end I made some wooden fencing for my garden rake which did the trick. I will shovel/barrow most of it. Can you get a rake with a flat plate head? No prongs?
