flanagaj Posted June 29, 2024 Posted June 29, 2024 I have just made a start dismantling the old cattery pens from the plot we have purchased.  I spent sometime reading whether I needed to file a demolition request to the council before I started dismantling. I say dismantling, as a charity is taking the pens to reuse them. So I took it that as they are being dismantled and are basically wooden pens, that a demolition notice was not required.  Now the next job I need to really do, is to to remove the hedgerow / trees that were marked for removal on the planning application (I understand that if birds are nesting, I cannot remove them). This is so that I can create a temporary driveway into the plot so that cement trucks / grab lorries can reverse into the plot as opposed to blocking the highway.  The reason for the post is that I am rather confused as to what tasks I can just get on with, and what requires some sort of paperwork to be filed with the council.  Eg, I don't know whether site preparation / clearance is deemed as building has started.  My wife and I are also considering putting in a new planning application, and am unsure whether doing that is best done having not done any work on the site.  The site clearance / temporary driveway works are required regardless of whether we build what is currently agreed or whether we get a new app approved.  Any pointers welcomed, as I have become a bit of a nervous wreck when on site as I am continually worrying that the neighbours will be looking for any excuse to report me to the council. Â
Alan Ambrose Posted June 29, 2024 Posted June 29, 2024 If your LPA doesn’t charge CIL, then several on here have started and then changed plans mid-flight. I’m sure they be along in a minute. A different matter if CIL is involved. 1
flanagaj Posted June 29, 2024 Author Posted June 29, 2024 8 hours ago, Alan Ambrose said: If your LPA doesn’t charge CIL, then several on here have started and then changed plans mid-flight. I’m sure they be along in a minute. A different matter if CIL is involved. I did contact Basingstoke & Deane regarding CIL, and they replied. "As there is no CIL charge, In accordance with CIL Reg 67 (1A)(b) no Commence Notice is required and no further action will be required with respect to CIL." Â
joe90 Posted June 29, 2024 Posted June 29, 2024 Just tell them you are about to start, crack on, 🖕to the neighbours then decide if/when you want to change your plans. 1
flanagaj Posted June 29, 2024 Author Posted June 29, 2024 19 minutes ago, joe90 said: 🖕to the neighbours The neighbour who sold us the plot and then insisted we met a couple of times in person, has now gone completely cold on me when I sent them an email of the revised house design we want to go with. They didn't even respond to my email. I wish I hadn't bothered now.. 1
joe90 Posted June 29, 2024 Posted June 29, 2024 3 minutes ago, flanagaj said: wish I hadn't bothered now.. Well at least you tried, their loss, just crack on and they can see what you propose from the planning portal. 1
Alan Ambrose Posted June 30, 2024 Posted June 30, 2024 >>> As there is no CIL Â Fantastic, so you can file a carefully thought out mix of non-material, minor and full plans. Also when fulfilling conditions (materials say) you can change the original application. e.g. you could propose fairly different materials to the original application and, if accepted, you have just achieved a minor amendment by the back door. 1
flanagaj Posted June 30, 2024 Author Posted June 30, 2024 1 hour ago, Alan Ambrose said: >>> As there is no CIL  Fantastic, so you can file a carefully thought out mix of non-material, minor and full plans. Also when fulfilling conditions (materials say) you can change the original application. e.g. you could propose fairly different materials to the original application and, if accepted, you have just achieved a minor amendment by the back door. This sounds very interesting.  So although the original application stated a clay tile roof / timber windows, could I then propose a seam seal roof and aluminium windows, or would that be a step too far?
