I'm going to lay T&G OSB and with its long edge perpendicular to joists, any short edges need to land on a joist or I have to add noggins. Same with chipboard I think. If it wasn't for the T&G, I think I'd just take the wastage and cut the sheets to fit the joists rather than adding noggins.
What's the best way to do this. I can think of three options in decreasing robustness order:
  1. H shape with two noggins between joists and under board's long edges, then a noggin between those where the board's short edge is
  2. Just the two noggins between joists and under board's long edges
  3. A single noggin under the board's centre line parallel to the board's long edges
Edited by MortarThePoint
2 minutes ago, nod said:
If they are glued You don’t need nogs
+1, the t@g supports the edges, you only need noggins if square edged sheets.
That's not what the Sterling osb installation guide says though. Might be right for chipboard
Use cabba deck then
