Dan92 Posted May 19, 2024 Share Posted May 19, 2024 Hi currently digging footings for a small 4x4m single story flat roof extension and have found a private drain about 600mm deep and footings are going to be at 1000mm deep is the drain okay to run through the footing and if so is it okay just to sleeve it or will it need to be relocated. Thanks guys any info really appreciated Link to comment Share on other sites More sharing options...
DevilDamo Posted May 19, 2024 Share Posted May 19, 2024 No. Your options would be to reduce the depth of the extension, increase the depth of the extension or provide new foundations beyond the sewer and lintel over. Link to comment Share on other sites More sharing options...
nod Posted May 19, 2024 Share Posted May 19, 2024 We had a similar situation at our last house Building control insisted that we cut the drain off and put two inspection chambers in and run the new drain parallel to the footings Id give BC a call and get him or her out Link to comment Share on other sites More sharing options...
Dave Jones Posted May 19, 2024 Share Posted May 19, 2024 is it shared with anyone else ? Guessing it is otherwise you could simply move it. In which case its more than likely adopted and you will need build over permission. Link to comment Share on other sites More sharing options...
Conor Posted May 19, 2024 Share Posted May 19, 2024 14 hours ago, Dan92 said: Hi currently digging footings for a small 4x4m single story flat roof extension and have found a private drain about 600mm deep and footings are going to be at 1000mm deep is the drain okay to run through the footing and if so is it okay just to sleeve it or will it need to be relocated. Thanks guys any info really appreciated What do you mean by private drain? Do you know where it starts and what it's connected to? If it's a shared surface water drain, then it's public, and usual policies of the owner will apply. Usually a draconian 3-4m buffer. Link to comment Share on other sites More sharing options...
