Sparrowhawk Posted May 13, 2024 Author Posted May 13, 2024 Cheapest breathable membrane I can find to go over the joists and hold the mineral wool in place is https://www.fixdirect.co.uk/product/breathable-membrane-100gsm/ at £35.50 for 50m. Will that do the job or at 100gsm tear too easily? They also do 140gsm which is still a hell of a lot cheaper than Pro Clima Solitex Plus (170gsm).
MikeGrahamT21 Posted May 13, 2024 Posted May 13, 2024 (edited) A few bits which i'm not quite sure I'd agree with here... Marmox is in no way strong enough to go on top of the joists and under the chipboard/OSB layer, it would get crushed in the areas of contact, once a lot of weight is put on the floor. You would have to put this layer on top of chipboard/OSB layer and either top with 10mm self leveller compound if you are to use carpet, or by using a wood flooring/engineered wood/LVT/Laminate, and use a thin 2mm EPS under the solid flooring to prevent it touching the rough cement layer on the Marmox. I'm using Marmox under underfloor heating in bathroom, and me just kneeling on it has left a few dents, so it definitely needs something else to spread load. On 09/05/2024 at 08:23, Sparrowhawk said: I like this idea. Is Marmox strong enough to replace chipboard in the floor build up, or needs that on top of it? Longer term the floor level will be raised in this room by ~20mm; it's a half/half mix of old suspended wood floor and (we think) beam and block. Which is probably uninsulated. I thought lifting the floorboards would show me a cross section of the beam and block but they whacked 2 joists across the join so going to have to try harder to determine its make-up and if there's any insulation in it. No, do not use Marmox for this purpose, it is only XPS insulation sandwiched between two 1mm reinforced cement layers, it is not designed for point loads such as sitting on joists, and needs to be fully supported. On 11/05/2024 at 11:42, Sparrowhawk said: Where this laps up the wall and is taped, you can't plaster onto polythene right? So it needs to be a small lap and plaster onto the Tescon Vana tape - or the wall replastered first and then this has to be done after? You need to use specific tape which is 'plaster-in', such as https://www.airstop.co.uk/product-page/airstop-flex-fee You will need a primer to put on the block/brick work first, and then tape your membrane down with this style tape. You are then ready to plaster in. Most primers are paint on, however I have just discovered Tescon's SPrimer, which is spray primer, though i've yet to use it so can't comment on how good/bad it is. Edited May 13, 2024 by MikeGrahamT21 2
Iceverge Posted May 13, 2024 Posted May 13, 2024 @Sparrowhawk Sorry I've been skimming this thread, dropping in and out. Missed the bit about going back to mineral wool. Pragmatic decision I say. 16 hours ago, Sparrowhawk said: the timbers should be fine, it's whether to make the glass mineral wool able to breathe. Sound like Frankenstein's insulation monster. Throw "breathing" out the window I say. Replace it with materials of differing "vapour permanbility". It more accurately reflects reality. Some backyard experiments may help you to get a feeling for this. Get some leaves/grass clippings and sandwich them between two layers of your various materials and tape the edges. Put them in a dry environment and wait. Anything that looses it's moisture means the material has an appropriate level of permanbility. Anything that doesn't, eg plastic DPM will see the organic material rot and go manky. AVOID 2 LAYERS OF THIS TYPE OF LOW PERMANBILITY MATERIAL AT ALL COSTS!!! Even right next to each other as moisture will find it's way in there and be unable to get out.
Iceverge Posted May 13, 2024 Posted May 13, 2024 (edited) TBH I think going with the very first pic from environmental building supplies is the one to peg for, done well it'll be absolutely fine. A U value of 0.35 is still 3 times better than the very best 3g windows once installed so pick your battles. Material wise.... I really like Glidevales VP400 breather membrane for below the insulation. £140 from Screwfix. In any case get something with a good g/M2 figure (>140g/m²), good tear resistance (>200N) and a low SD value ( <0.03m) It is airtight so you could use it above too rather than buying a separate airtight membrane. It would be a good choice given its pretty tough. If you do want a separate airtight membrane look for a mass of >100g/m² and a tear value of >200N. I like the semi transparent ones as you can see the studs + insulation etc behind it. Something like Powerlon VCL170 can be bough for about £1.15 per M2 and will work every bit as well as in this application as Proclima DA at £2.66/M2. As for insulation. As well as the K value look for the density of mineral wool. 10kg/M3 is much harder to cut and fit accurately than 35kg/M3. Edited May 13, 2024 by Iceverge 1
Sparrowhawk Posted May 19, 2024 Author Posted May 19, 2024 Which side of Glidevale VP400 lets moisture out - the printed side? Or it doesn't matter which way up it's installed?
MikeGrahamT21 Posted May 19, 2024 Posted May 19, 2024 8 hours ago, Sparrowhawk said: Which side of Glidevale VP400 lets moisture out - the printed side? Or it doesn't matter which way up it's installed? always printed side to where you want the moisture to go, think of how it’s used on a roof 1
PlaneIron Posted April 27 Posted April 27 On 19/05/2024 at 10:32, Sparrowhawk said: Which side of Glidevale VP400 lets moisture out - the printed side? Or it doesn't matter which way up it's installed? Did you use the VP400 under the insulation and which side did you install up? I have followed ecological building approach (first pic in your first post) using their materials but have ran out of solitex plus and only need another 3m of solitex plus to finish and don't want to buy another roll given the cost. The solitex is installed printed face up so is the VP400 also printed up or printed down. I'm stupid and @MikeGrahamT21 response has stumped me.
PlaneIron Posted April 27 Posted April 27 I'm going to answer my own question. It apparently doesn't matter as long as you tape the smoother printed side. So if installed from above or below, the printed side always faces the installer. This is from the website https://www.ecologicalbuildingsystems.com/post/best-practice-approach-insulating-suspended-timber-floors?srsltid=AfmBOoqOy6uXw7XQNPD9PKJ_QPzO_bIA5AQdWig7Z_BceuyqN-8X8662 Which way up should the membranes be installed? For Solitex Plus, when installed on a suspended timber floor, there is no UV exposure, so the blue face should be positioned so it is the side that gets taped. This means, if the floorboards have all been removed and you install from above the floor, the printed blue side will face up (towards the interior of the room). Conversely, if the floorboards remain in-place and you install from within the crawl space underneath, the blue side will be facing down towards the earth. Taping should always be done onto the blue face as it is smoother and an ideal surface for airtight tape. The same is true for the DA membrane; tape the side you can see and make sure you position it so that would be the dark green face for the DA.
saveasteading Posted April 27 Posted April 27 2 hours ago, PlaneIron said: the printed side always faces the installer. and anyone else likely to note the name. It's good advertising. Otherwise they could print on it 'this side faces the installer' I guess they could add that anyway.
