NandM Posted April 25, 2024 Share Posted April 25, 2024 So I've had around three quotes so far for blown-in EPS (150sqm of wall @ 200mm cavity) and they are all within the £4K - £4.5K range...this is much more than I thought it would be given some of the historic quotes on this forums (2021/2022). Which brings me to the question of using non-"branded"/BBA/KIWA certified EPS beads and going down the DIY route as per the other thread. Would there be any push back from building control if I was to use beads without a certificate? Link to comment Share on other sites More sharing options...
nod Posted April 25, 2024 Share Posted April 25, 2024 No there wouldn’t be BC don’t get into brands and is unlikely to ask for certification As always Plenty of pictures 1 Link to comment Share on other sites More sharing options...
Mr Punter Posted April 25, 2024 Share Posted April 25, 2024 You warranty provider would want certification, so not DIY. The manufacturer of the blown in cavity wall insulation must operate an approved installer scheme where the installers are approved, registered and regularly reviewed or demonstrate they are competent to carry out installations of the product in accordance with the third party product conformity certificate. Evidence of the installer being approved by the manufacturer should be made available to the Warranty Surveyor upon request. 1 Link to comment Share on other sites More sharing options...
NandM Posted April 25, 2024 Author Share Posted April 25, 2024 I had another quote at £4.9K and just as I was about to give up on using an installer, I had an Ecobead Platinum approved installer quote me £2.4K. I haven't thought about warranty - would this be applicable to an extension? I have found someone selling almost 20m3 (I need 28m3) of grey beads for just under £300, but delivery doubles that to £600. If I add to that a half-decent setup for the installation, then financially I'm looking at under a grand to do two-thirds of what I need. Which made a lot of sense with the previous quotes I had, but still tempting with the lower quote....plus storage would be a nightmare. Link to comment Share on other sites More sharing options...
Redbeard Posted April 25, 2024 Share Posted April 25, 2024 1 hour ago, NandM said: I had an Ecobead Platinum approved installer quote me £2.4K. I could be wrong but I believe that a lot of cavity wall insulation companies are members of a self-certification body, so they can sign off against Bldg Regs. However I feel pretty jolly certain that they could not sign off a job which was not a cavity wall. Link to comment Share on other sites More sharing options...
ADLIan Posted April 25, 2024 Share Posted April 25, 2024 This work is notifiable under the building regs. At the least the manufacture and install should be in accordance with BS EN 14064. Product needs to be CE/ UKCA marked as there is a designated/harmonised BS EN. Not sure how you would even confirm the thermal conductivity, once installed, of random beads bought from eBay never mind all other declared physical properties and weather resistance. Building Regs require these products to have 3rd party certification (BBA or similar) for both the manufacture and installation. Approved systems installed by approved contractors are generally deemed to comply with the Approved Doc without a building reg application. In short DIY is a non starter. Link to comment Share on other sites More sharing options...
ADLIan Posted April 25, 2024 Share Posted April 25, 2024 (edited) To clarify, above standard is for blown in mineral wool. No equivalent* Standard for eps beads but same BBA standard and test methods for manufacture & install *there is an equivalent BS! BS EN 16809. Edited April 25, 2024 by ADLIan Correction 1 Link to comment Share on other sites More sharing options...
NandM Posted April 26, 2024 Author Share Posted April 26, 2024 I've raised the question with our council planning officer and will report back. Link to comment Share on other sites More sharing options...
Redbeard Posted April 26, 2024 Share Posted April 26, 2024 Would the planners be interested? Surely this is a Building Control and Compliance thing? Link to comment Share on other sites More sharing options...
NandM Posted April 29, 2024 Author Share Posted April 29, 2024 That's a good point! Link to comment Share on other sites More sharing options...
Mr Punter Posted April 29, 2024 Share Posted April 29, 2024 I recently got some quotes for EPS bead insulation in a new build 150mm cavity. 135.8m2 net of wall area, 20.37m3 volume. First quote: £8,890!!!!!!!! Second quote: £4,080 Third quote: £1,453 Link to comment Share on other sites More sharing options...
NandM Posted April 30, 2024 Author Share Posted April 30, 2024 Oooh - can you share details of who gave you the third quote? The best I've had is £2.5K for 28m3. Link to comment Share on other sites More sharing options...
