Chanmenie Posted April 3, 2024 Posted April 3, 2024 Can I ask opinions and experiences please, i'm trying to decide on how best to construct shower areas. Both showers will have Nuance shower panels, so what do I do underneath. Downstairs bathroom is blockwork walls and concrete floor, upstairs is studwork and 22mm Caberdek P5. Option 1, Tile backer boards or aquapanel etc Option 2, green plasterboard and liquid tanking solution. (what liquid would you recommend) Thanks in advance
JohnMo Posted April 3, 2024 Posted April 3, 2024 We just have green plasterboard, then tiles. Never seen why you need to tank. Every house I have lived in, has been the same (since the 80s).
bassanclan Posted April 4, 2024 Posted April 4, 2024 Definitely tank it. Doesn't matter which system, they are all basically liquid rubber. Get a kit which comes with the tape, which you need for corners and joins.
Mike Posted April 4, 2024 Posted April 4, 2024 If it's a wet-room - with tiles instead of a monolithic shower tray - then tank it. If you have movement joints between the floor and wall, then tank it with properly detailed joints. Otherwise no need.
Chanmenie Posted April 4, 2024 Author Posted April 4, 2024 47 minutes ago, Mike said: If it's a wet-room - with tiles instead of a monolithic shower tray - then tank it. If you have movement joints between the floor and wall, then tank it with properly detailed joints. Otherwise no need. Im fitting a low profile shower tray flush with floor, the Nuance shower panels will be sealed onto the shower tray. The downstairs bathroom is concrete floor and block walls so no movement, the upstairs bathroom will also have a shower tray and is studwork but it’s screwed to the floor so I don’t expect movement.
Mike Posted April 4, 2024 Posted April 4, 2024 2 hours ago, Chanmenie said: Im fitting a low profile shower tray flush with floor, the Nuance shower panels will be sealed onto the shower tray. The downstairs bathroom is concrete floor and block walls so no movement, the upstairs bathroom will also have a shower tray and is studwork but it’s screwed to the floor so I don’t expect movement. Sounds like you're good to go :)
