MortarThePoint Posted March 25, 2024 Share Posted March 25, 2024 The plasterer is pretty much done now, so the next external trade I have is the tiler who I am currently looking for but thinking about what I need done before they start. The rooms to be done are: Bathrooms (floors, walls to just over window cill level and shower cubicles to above head height) Loo (floor possibly wall to just over window cill level) Kitchen / Family room (floor) Utility (floor) I am trying to work out the jobs I need to get done before the tiler can start and think the list looks like: Bathrooms: plumb 110mm soil pipe to toilet position but not fit toilet(?) plumb shower feeds to shower bar tank shower area fit shower tray and waste plumb shower waste to soil stack fit & plumb bath with box-in frame but not fit panel (v-groove timber) plumb (feed and waste) basin as far as is behind tiles but not fit basin unless it is solely wall mounted (i.e. not vanity or pedestal) Loo: fit any plumbing connection points that are to stick through the tiling understand how waste will connect to stack connection in floor and make any adaptations needed Kitchen / Family: trim island 'conduit' (110mm soil pipe used) to near flush with floor so it doesn't stick up too much above tile though careful to avoid allowing mopping water to enter this so worth being >1cm above finished tile level extend screed into the exterior door thresholds. this is because I had the screed done before fitting door steps or doors (wouldn't do that again) Utility: fit door lining to cupboard extend screed into the exterior door threshold Screed was fitted >12mo ago and I have already had the UFH flow higher than likely end use temperatures. Any thoughts as to what I have overlooked? Link to comment Share on other sites More sharing options...
nod Posted March 25, 2024 Share Posted March 25, 2024 Make sure all the walls are finished and grouted before any prep work is done to the floors They need prepping tiled grouted Then protecting till your ready to move in 2 Link to comment Share on other sites More sharing options...
MortarThePoint Posted March 26, 2024 Author Share Posted March 26, 2024 16 hours ago, nod said: Make sure all the walls are finished and grouted before any prep work is done to the floors They need prepping tiled grouted Then protecting till your ready to move in Am I right to think toilet bowl and basin pedestal don't get fitted until after tiling? Link to comment Share on other sites More sharing options...
BotusBuild Posted March 26, 2024 Share Posted March 26, 2024 I would ensure you have any pipes or conduits in place but not trimmed all the way back (do that after the tiling) Fit your toilets and pedestals after the tiling. If they get changed in the future you won't end up with holes in the tiling where you don't want them. 1 Link to comment Share on other sites More sharing options...
nod Posted March 26, 2024 Share Posted March 26, 2024 8 hours ago, MortarThePoint said: Am I right to think toilet bowl and basin pedestal don't get fitted until after tiling? Yes 1 Link to comment Share on other sites More sharing options...
MortarThePoint Posted March 27, 2024 Author Share Posted March 27, 2024 19 hours ago, BotusBuild said: Fit your toilets and pedestals after the tiling. 10 hours ago, nod said: Yes I assume shower trays are a different matter though as they get tiled down to on the wall don't they? Link to comment Share on other sites More sharing options...
nod Posted March 27, 2024 Share Posted March 27, 2024 37 minutes ago, MortarThePoint said: I assume shower trays are a different matter though as they get tiled down to on the wall don't they? Yes get your shower tray in and protected 3 Link to comment Share on other sites More sharing options...
MortarThePoint Posted July 29, 2024 Author Share Posted July 29, 2024 I've heard some people say it's better to tile without the bath in place. What's the best approach here? The bath will sit in a timber frame so I could build that to provide an accurate reference for the tiler to hold the tiles back from. Link to comment Share on other sites More sharing options...
Dave Jones Posted July 29, 2024 Share Posted July 29, 2024 On 26/03/2024 at 20:23, nod said: Yes unless you want tiles above the basin/spalshback in which case probably best to have it fitted. 1 Link to comment Share on other sites More sharing options...
