Nic Posted March 19, 2024 Posted March 19, 2024 I have a small two bed project for later this year and would like some advice please on lighting. I know I need a mix of task ambiance etc but also want to have them all dimmable and controlled via an app and switch. anyone advise on who can help with a plan and what I need to look at, so when I have an electrician I can at least have some ideas. layouts should be something like below. Will need to consider outside as well but I’ll concentrate on inside first 🙏
Mike Posted March 20, 2024 Posted March 20, 2024 On 19/03/2024 at 10:20, Nic said: what I need to look at Here's a start: 1
MikeSharp01 Posted March 21, 2024 Posted March 21, 2024 7 hours ago, Mike said: Here's a start: Yes @Nic that's a great link - gets a heap of professional advice from @Carrerahill who has a degree in lighting design. 1
garrymartin Posted March 21, 2024 Posted March 21, 2024 The John Cullen lighting webinars are really good - https://www.johncullenlighting.com/events/#webinars 1
Thorfun Posted March 21, 2024 Posted March 21, 2024 for a property that size you might find that a good lighting designer is not as expensive as you think. 1
Nic Posted March 21, 2024 Author Posted March 21, 2024 2 hours ago, Thorfun said: for a property that size you might find that a good lighting designer is not as expensive as you think. Know of any you can recommend? Thanks 🙏
Thorfun Posted March 21, 2024 Posted March 21, 2024 2 hours ago, Nic said: Know of any you can recommend? Thanks 🙏 This is who we used https://www.eslightingdesign.co.uk 1
